Oil Drain from turbo to oil pan
everytime i start my car or when i shut it off, the hose from the drain of turbo to oil pand has a small leak and when i touch it, its all oily. im using a steering pump rated at 250 psi. should i use something else?
i ♥ my honda
Global Mod
Global Mod
Re: Oil Drain from turbo to oil pan (civicsaremean)
What are you talking about a steering pump for?
Sounds like a simple leak to me. What type of hose are fittings are you using?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicsaremean »</TD></TR><TR><TD CLASS="quote">everytime i start my car or when i shut it off, the hose from the drain of turbo to oil pand has a small leak and when i touch it, its all oily. im using a steering pump rated at 250 psi. should i use something else? </TD></TR></TABLE>
Steering pump??
Are you saying your using a pressure hose from a power steering pump as the drain hose? Is the hose the right size? Is oil leaking from the ends or is coming through the hose itself?
Steering pump??
bluebluecivic2
05-23-2016 03:30 AM
