how much boost
Old Dec 23, 2007 | 12:25 AM
ser13's Avatar
Default how much boost
i just put a t3/t4 50 ar trim on my em1 it currently untuned and stock hiw much pounds of boost would it have
Old Dec 23, 2007 | 12:27 AM
CoreyR's Avatar
Default Re: how much boost (ser13)
id run at least 45psi on that setup.
Old Dec 23, 2007 | 01:29 AM
blinx9900's Avatar
Default Re: how much boost (CoreyR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CoreyR &raquo;</TD></TR><TR><TD CLASS="quote">id run at least 45psi on that setup.</TD></TR></TABLE>
i very much like this idea
F
Old Dec 23, 2007 | 05:16 AM
MrMoe's Avatar
PSI is irrelevant. Different turboes are going to make different power leverls at different PSI numbers. You should be more concerned with how aggressive your motor can be tuned before something breaks
Old Dec 23, 2007 | 07:59 AM
turbodano's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ser13 &raquo;</TD></TR><TR><TD CLASS="quote">i just put a t3/t4 50 ar trim on my em1 it currently untuned and stock hiw much pounds of boost would it have</TD></TR></TABLE>
There are a few good turbo shops in your area, I would advise you to find a shop to tune your car and make sure they deal with Hondas.
Old Dec 23, 2007 | 10:07 AM
Schister66's Avatar
Man U FTW
If your car is untuned and stock, you shouldnt be seeing any boost unless you like rebuilding engines. Once it is tuned properly, you could be somewhere in the 12-14psi range which will net you about 300whp. The pressure to get there is irrelevant...power is what kills engines
prhatch124
Dec 28, 2007 07:49 PM
trex352
Jun 6, 2007 09:04 PM
SPOOLINmatt
Nov 22, 2005 11:54 PM
ying_YANGtwin
Dec 16, 2004 05:55 PM
Sam1am26
Nov 26, 2004 06:51 PM
