how harmful are boost spikes?
Old 01-06-2008, 12:56 PM
97grnrs's Avatar
Default how harmful are boost spikes?
just wondering. cause im pushin my stock block to the max pretty much as it is and im gonna be running about 12 psi solid on a 57 trim turbo and i always get a 2-3 psi spike for about 2-3 sec till it settles down. will this hurt it or is that short amout of time not a big deal? i do run a lil on the rich side so i think the tune is ok for it but the stock block will only take so much
Old 01-06-2008, 12:58 PM
Man U FTW
Schister66's Avatar
Since you're not tuned for those higher boost levels, i would say that its pretty dangerous....especially on a stock block. Stock ringlands are known to be weak so it might not take much to blow it up
Old 01-06-2008, 03:16 PM
DLB1994's Avatar
Default Re: (Schister66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">Since you're not tuned for those higher boost levels, i would say that its pretty dangerous....especially on a stock block. Stock ringlands are known to be weak so it might not take much to blow it up</TD></TR></TABLE>
the day ring landing break and end up in the oilpan let me know!!! lol
Old 01-06-2008, 03:19 PM
T4eg's Avatar
Default Re: (DLB1994)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DLB1994 &raquo;</TD></TR><TR><TD CLASS="quote">
the day ring landing break and end up in the oilpan let me know!!! lol </TD></TR></TABLE>
lmao
Old 01-06-2008, 03:29 PM
97grnrs's Avatar
Default Re: (T4eg)
actually i am tuned to go up to any boost level, but im just not sure how much the oem block will take pressure wise.. i am cranking out a decent amount of power off the stock block i know i am . so i dunno how much farther i can boost before something bad happens
Old 01-06-2008, 03:35 PM
DLB1994's Avatar
Default Re: (97grnrs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97grnrs &raquo;</TD></TR><TR><TD CLASS="quote">actually i am tuned to go up to any boost level, but im just not sure how much the oem block will take pressure wise.. i am cranking out a decent amount of power off the stock block i know i am . so i dunno how much farther i can boost before something bad happens </TD></TR></TABLE>
if its tuned on some real ems , and its a good timing map with nice rich air/fuel.., you will be just find with that lil bit of spike , if tuned right stock blocks has been know to handle much more!!!!
Old 01-06-2008, 04:01 PM
97grnrs's Avatar
tuned on zdyne by me. and ya it will handle that but i wasnt sure how well off it was as my daily driver ..
Old 01-06-2008, 04:36 PM
usdm97DC4's Avatar
do you have a fuel cut if you should hit an abnormally high boost?
Old 01-06-2008, 04:40 PM
97grnrs's Avatar
Default Re: (usdm97DC4)
unfortunately zdyne has no fuel cut for overboost. so its by eye only.
Old 01-06-2008, 04:57 PM
usdm97DC4's Avatar
yikes, be careful then
Old 01-06-2008, 04:59 PM
97grnrs's Avatar
ya i know.. i like the zdyne but its a lil old. and dont have some of the stuff i wish it did. but it works well
Old 01-06-2008, 06:41 PM
Topdawgg's Avatar
boost cut?
Old 01-06-2008, 07:07 PM
97grnrs's Avatar
Default Re: (Topdawgg)
no. that what the other guy asked. zdyne doesnt have a boost cut feature
BOMBCRU
08-04-2022 08:21 PM
japspecb7
04-17-2007 04:18 PM
sPaRk'iT
06-12-2004 11:19 PM
B18 CYA
04-07-2004 03:43 PM
wm5holla
05-01-2003 07:48 AM
Quick Reply: how harmful are boost spikes?
