How does the boost cutoff work on hondata?
Yesterday after putting in a highflow cat I took my car for a test drive. After doing a 2nd to 3rd shift I noticed a cel. I pulled over and it read code 10. I figured since I have a slight problem with boost creep and I replaced my test pipe with a cat that I must have hit the boost cutoff. I was wondering if someone could explain how it works and what it does exactly.
Thanks,
Jimmy
Thanks,
Jimmy
code 10 is:
IAT Sensor (Intake Air Temperature) defective circuit or unplugged / defective sensor
for boost cut.. i don't think hondata can control boost, you'd need boost controller for that.
Hondata does indeed have a boost cut feature. i cant remember if it cuts fuel or spark though. I think it see's the voltage from the map sensor and if it exceeds what you have it set for it will cut then . i believe with hondata it cuts fuel though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 »</TD></TR><TR><TD CLASS="quote">Hondata does indeed have a boost cut feature. i cant remember if it cuts fuel or spark though. I think it see's the voltage from the map sensor and if it exceeds what you have it set for it will cut then . i believe with hondata it cuts fuel though. </TD></TR></TABLE>
i thought thats just called fuel cuttoff. same thing i had on non-boost version of hondata, unless it cuts fuel according to boost level. i think its much safer to have an additional device to maybe cut ignition or best boost cut, i run 3psi spring and my boost cuts at 10-11psi.. its overboost feature on my boost contorller.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec.dc2 »</TD></TR><TR><TD CLASS="quote">
unless it cuts fuel according to boost level</TD></TR></TABLE>
Exactly what it does and it doesn't harm anything. I have hit it many times.
I said i hit boost cut once i think , it just so happens thats the run my motor blew, wa sit due to that ? that answer will never be found out. it prob ran too lean and detonated. but it sure as **** felt like boost cut to me .and my log didnt go past the set boost cut? so i dunno . it prob doesnt pertain to this. so ill leave it at that. i just dont trust anything pulling fuel
So once you hit the cutoff it cuts fuel and just lights up. I hit again today, but had my b/c set at 8psi and my cut off is 11psi. This might be part of the hiccup problem I have with the hondata.
I was set at 15psi with hondata and then put on a full 3" exhaust and new intake manifold...Took it for a spin and hit the 20psi mark and hondata shut it down. I thank God for that too. I had to turn my boost controller down a bit due to the increase in exhaust flow.
for hondata boost limit feature.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 »</TD></TR><TR><TD CLASS="quote">how would you hit Boost cut if your BC is set for 8psi and the hondata is set for 11psi ?</TD></TR></TABLE>
The guys at hondata think my hiccup problem is due to a noisy MAP senor. If my b/c is reading 8 and the map sensor is picking up something different like 11 then I would throw a code. But who knows? Maybe I'll figure it out one day.
JusT a Cx
Feb 24, 2004 05:58 PM
