hondata and boost controller question??????????????????????
Old Feb 23, 2004 | 04:57 PM
JusT a Cx's Avatar
Default hondata and boost controller question??????????????????????
i have hondata s100B and iam about to have it tuned..... and i know a boost controller is not necessary with hondata.. but should i get a map installed soo i can have hondata and b-controller and toggle between boost settings or just have one constant setting and no boost controller??
what do u guys think i should do ??
Modified by JusT a Cx at 11:01 AM 2/24/2004
Old Feb 23, 2004 | 05:11 PM
xenocron's Avatar
Default Re: hondata and boost controller question?????????????????????? (JusT a Cx)
You can always get it tuned to your low boost setting first, then buy the new MAP and get the higher boost tuned later down the road.
Just dont boost high until you get it tuned.
Old Feb 24, 2004 | 08:05 AM
JusT a Cx's Avatar
Default Re: hondata and boost controller question?????????????????????? (xenocron)
any one ???
Old Feb 24, 2004 | 08:14 AM
Killer_B's Avatar
get your 3Bar Map and Boost Controlllerbefore the tune. No need to get it tuned twice if not necessary. when they tune your car they will start with the lowest boost setting that you have and increase the boost level to the maxium setting that your set up (motor) can handle.
once it's tuned you can set your boost to the low setting for daily driving.
Old Feb 24, 2004 | 08:43 AM
lucrative's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JusT a Cx &raquo;</TD></TR><TR><TD CLASS="quote">i have hondata s100B and iam about to have it tuned..... and i know a boost controller is not necessary with hondata..
Modified by JusT a Cx at 11:01 AM 2/24/2004</TD></TR></TABLE>
Just out of curiousity, how is a boost controller not necessary with hondata? ...I know a wastegate helps regulate the boost... but how would hondata also regulate it? Does it do it electronically with a sensor of some sort or does it do it manually?
Old Feb 24, 2004 | 04:03 PM
JusT a Cx's Avatar
Default Re: hondata and boost controller question?????????????????????? (lucrative)
hondata s100b comes with the boost setting feature and when u tune ur car say u want it at 10psi ,,,,, it will stay there and u cant go up or down .........so there for no controller needed but i was just wondering
Old Feb 24, 2004 | 04:24 PM
Cramerox's Avatar
hmmm sounds like a boost cut off switch. I was not aware hondata itself would be able to increase or decreas the boost. if it did, it means it would some how be connected to the WG. I think you will still need a boost controller. basically they will adjust the boost with the controller and tune each boost/Map settings. I am almost positive you need one.
Old Feb 24, 2004 | 05:58 PM
ek9turbo's Avatar
hondata cant control boost , but u can set the boost cut at a certain psi and it wont let u pass it.
now that means if u have a 7psi spring, hondata cant make u boost 5psi or 9 psi
u still need a boost controller to up the boost and choose a wastegate spring for ur
min boost
ochocinco
Engine Management and Tuning
Apr 8, 2010 12:44 PM
HondAcura
Northeast (Sales)
Jul 14, 2006 03:37 AM
BlackThorN
Dec 21, 2003 12:51 AM
Ek00fbp
Oct 8, 2003 10:08 PM
tgrace
Oct 7, 2003 01:52 PM
