How common is it to use 440cc High z injectors in a B18A1 turbochrged setup?
looking to turbo my b18a1 with a t3/t4 57 trim would 440cc injectors be fine? or bigger? |
re: How common is it to use 440cc High z injectors in a B18A1 turbochrged setup?
Good question, you're likely the first person ever to try turboing a B18 with 440cc injectors so a search will likely return nothing. Go forth carefully brave man
nah man plenty of people done this i’m sure but i’ve searched and searched oh what fuel injectors sz i would need and i seen someone has used 440cc but i’m trying to make sure.
Wow very tough. I searched “turbo b18a 440cc injectors” and found so many threads with info and dyno numbers I didn’t know what do to with myself. |
OP, you need to buy some knowledge.
You'll want to search further and look at fuel types (assuming pump gas here), power goals, and application.
Can you put a 440cc injector in while using a "T3/T4 57 trim"...yes. The actual question would be how much power would the 440cc injector support. |
I’m running 450cc injectors on my gsr engine and I’m at around 80% duty cycle and around 300whp. The dyno I was on showed 274whp. Like the above stated, all about your power goals |
Originally Posted by turboLScrx
(Post 51817675)
Re: How common is it to use 440cc High z injectors in a B18A1 turbochrged setup?
Originally Posted by JRCivic1
(Post 51818026)
What is your fuel pressure set at ???
