how big of a shot to run???
i was thuning of running nitrous on top of my turbo setup, but not sure how big of a shot i should go with, anyone got an ideas?
Re: how big of a shot to run??? (Boosted97Lude)
usaully or 40-60 shot would be great to spool up the turbo depending on the size you have. and also extra charge of cold air for the top end use is great. If its a stock motor ... https://honda-tech.com/forums/images...s/emsmileo.gif GOOD LUCK you can use dry kit with the proper fuel managementand upgraded injectors if not, you can go with a wet system to compensate for the extra fuel you will need
Re: how big of a shot to run??? (camp1320.com)
i was thinking of a direct port kit. spool up time is not the problem, top end is where i lack the most. i was wanting like a ..... 75 wet, direct port shot
Is your motor built if it is you can do it. I would run about a 50-60
Re: how big of a shot to run??? (HybridcivicLS-T)
oh yeah, it's built.... just about anything that could be done, was
Juice it! I think that would be a great setup.
Built turbo juiced lude. https://honda-tech.com/forums/images/smilies/emthup.gif you say you are lacking up top... just out of curiosity what MPH do you run in the 1/4? or is this just a seat of your pants thing. https://honda-tech.com/forums/images/smilies/embeer.gif |
Re: how big of a shot to run??? (T-sohctec)
Juice it! I think that would be a great setup. Built turbo juiced lude. https://honda-tech.com/forums/images/smilies/emthup.gif you say you are lacking up top... just out of curiosity what MPH do you run in the 1/4? or is this just a seat of your pants thing. https://honda-tech.com/forums/images/smilies/embeer.gif |
ttt
well, the smalles dp shot is a 80. the only way to get around this is to have a seperate regulator adjusting the pressure after the fuel t for just the n20.
if u need some n20 parts let me know...i got some cheaphttps://honda-tech.com/forums/images...es/emsmile.gif good luck on setup.. |
the NX kit i want is adjustable from 50hp up to 200hp, so, like a 75 shot with proper tuning should be safe, right?
bump
