highest hp on pump gas
Old Jan 22, 2009 | 05:09 PM
  #101
boostedeg6-1's Avatar
Default Re: highest hp on pump gas
Yup. sounds good lol!
Old Jan 22, 2009 | 09:32 PM
  #102
Tony the Tiger's Avatar
To elaborate more about pump gas limits vs octane, it's not just horsepower that we look at.
Torque is the critical factor. Have you noticed that a lot of the high power pump gas setups always revolve around large turbos, cams, headwork, etc? These motors in particular can carry the same amount of torque at a high RPM, thus, more horsepower.
It's a pretty common relationship, that a small turbo car will spool sooner, which also makes more torque. The natural physics behind smaller turbos also mean a choke at higher RPM, thus, lesser HP at the same amount of boost at higher RPM. Hence, small turbos trying to push big power on pump gas means less reliability.
You can almost guarantee that not too many cars out there can surpass 180-190 WTQ per L on pump gas (93oct) alone. Just do the math, almost every import engine, DOHC 4cyl or 6cyl, tends to follow this rule. We usually rule out slow burning engines however, like truck motors or low revving engines.
Look at Evos, a lot of the big power setups are strokers, 2.4L. They hover around mid 400-450 WTQ, thus, they can get decently safe 600 WHP at 8000RPM. Stock stroke 2.0L Evos, tend to stay around the same WTQ as our 2.0L B-series setups, hovering high 350-360 WTQ. On our Hondas and carrying 360 WTQ up at 9000RPM, this nets us 580-620 WHP at maximum state. Anything higher usually won't be too reliable.
Now look at Supras.. Pump gas limits on Supra for common T67 setups nets 520-550 WTQ, and these 2JZ-GTE motors usually holds this torque until 6200RPM (after that, it falls gradually). It nets them 640-660 WHP on pump gas, and around 22-24 PSI of boost. On built Supras, pump gas power ranges up to 750-780 WHP, of course, cams, built head, GT47 or larger turbos, etc.. They however, still make about the same 580 WTQ, but carrying it up to 7500RPM. Thus, now we get 780 WHP with the same torque, also with the same octane and about the same reliability.
All these engines follow the same 180 WTQ per L. Just don't go pass that and you should be safe.
Since I am from Canada, getting race gas is a b*tch.. I am ALWAYS on a mission to make as much on pump gas as possible. With the help from meth injection, it allows me to tune the car more aggressively on pump gas alone, and only use the meth to safeguard against bad batch of gas at the pumps, hotter weather, etc..
So far, it has been a little over 3 months and I am running at 560 WHP on 94 oct and meth (only a small jet).. No problems whatsoever because I only running 320 WTQ on my 1.8L, and my torque carries all the way to 9500RPM.
Old Jan 23, 2009 | 12:03 AM
  #103
Silva Bullit DC4's Avatar
^^^ Very good info. ^^^
Old Jan 23, 2009 | 05:05 AM
  #104
Tjabo's Avatar
Yeah, that is VERY well stated! I was just about to request that people in this thread start either posting up a bit more information about characteristics of their cams and turbo (to give a clue about the power band), or better yet, post an RPM at which they made the peak power number. For EXACTLY the reason you explained there T the T.
If you want to go fast on pump it seems like you've got to REV!
Old Jul 29, 2010 | 10:33 PM
  #105
AllShowNoGo727's Avatar
Im gonna see what a 6262 can make a on a 84mm ls vtec on pump, Goals are like 500 on pump but ill post a dyno sheet when done.
Old Feb 15, 2011 | 02:53 PM
  #106
Tjabo's Avatar
I am still a big fan of this post (below). It really resonates with me as far as making good power on low octane fuel.
Since I'm interested in seeing what I can do without my water/methanol injection system for the sake of curiosity, I was hoping to get some thoughts on good ballparks for timing at various RPMs.
Like for instance, I see people on here stating that they are using up to 15 degrees of timing at 22psi at 9,500 RPMs or whatever, but other people only using 4.5 degrees under similar circumstances, and seeing power go up as timing was taken out. At what point does removing more timing usually start to just jack up EGTs and maybe exacerbate boost creep?
I think it's clear that timing can safely be ramped up with RPM, but obviously has to slope down with boost pressure. So, can anyone offer any thoughts for a pump gas newbie (since I've been addicted to meth previously )?
Thanks in advance!!!
Old Feb 16, 2011 | 06:49 AM
  #107
hybrdthry911's Avatar
Ken from peakboost would offer some excellent advice on that exact topic if he wasn't ducking a few hundred people on here. His claim was that everyone with boost creep problems just didnt have aggressive enough tunes, and needed more timing.
I'm not a tuner but I would always bet on the safer route. I would rather have a little more "regular"(non detonation) cylinder pressure with an additional lb of boost and waste part of it with conservative timing VS risk having an "extreme" pressure spike a la detonation with a few additional degrees of timing trying to get every ounce of power and not have it creep.
Boost creep shouldn't be a factor when it comes to tuning, if you are tuning the car to what you feel is a safe timing curve and boost creep occurs, i would fix the lack of a properly sized wastegate system before making a tune more aggressive.
Old Feb 16, 2011 | 08:29 AM
  #108
Tjabo's Avatar
Thanks!
Are we really only talking about a really small amount of boost creep like that? If so that is a non-issue.
What about the EGT issue? Do the timing figures have to be in the AFTER TDC area ala anti-lag for the EGTs to get out of hand, assuming that the fuel curve is reasonable?
Old Feb 16, 2011 | 08:52 AM
  #109
D-Rob's Avatar
Thanks!
The whole Ken Peak tuning-ideology came about from a post I made on ClubRSX last year regarding a customer's car that had one of his turbo kits on it (K20 RSX, PB manifold, GT35R with .82 exhaust side), and it's inability to hold anything lower than 21-22psi from a 7psi spring.
The wastegate would open at 7-8psi, and creep to 22psi or so by 8,400 RPM.
Long story short, he pretty much told me I didn't know what I was doing, blah blah blah. They held a "Peakboost Appreciation Day" at a shop in Maryland specifically to "fix" several cars that were experiencing the same major boost control problems, and needless to say, nothing was ever "fixed."
The people that had creeping issues before that day left with the same problems.
Combined with his personal arrogance, his sheer lack of intelligence, and his terrible business etiquette, I like to think I helped put a nail or two in Peakboost's coffin.
Sorry for the tangent!
- Derek
Old Feb 16, 2011 | 09:49 AM
  #110
- Derek
I used to work at a company that makes a lot of turbo manifolds. We would always find out the customers engine specs and hp goals and recommend a properly sized wastegate for the application and in a lot of cases dual wastegate setups when needed. Many people would, against our better judgement, choose a single 44mm only to be let down when it has boost creep.
Ken has been a scumbag for years, unfortunately H-T let their members down by allowing that business to operate and hid thread after thread of customers that got screwed by him. Not to mention the employees he screwed over the years.
Old Feb 16, 2011 | 09:54 AM
  #111
Thanks!
At the timing values I've used over the years for my turbo B series which have never been below 12-14 degree's on pump gas EGT has never been an issue, and i did have some boost creep issues until i ran a dual WG setup. I even ran my buddies old entire turbo kit hat held 9psi on his engine wouldn't hold 13-14psi on mine so the kit itself wasn't flawed, each engine is different and must be treated accordingly.
Old Feb 16, 2011 | 01:43 PM
  #112
Tjabo's Avatar
Thank you for some extremely helpful "on-point" information guys!!!! You can't always get high quality information on the internet, so I really appreciate it.
Old Feb 16, 2011 | 06:42 PM
  #113
93lsv_turbo's Avatar
Wow this thread went every way except number (ok there were a few numbers). Fun and informative thread
Old Feb 17, 2011 | 02:13 PM
  #114
extralargenog's Avatar
Holy BFTD thread...
This made me LOL......
Originally Posted by boostedeg6-1
I was on a dynapac... has been proven to read lower then dynojet and mustang dyno's..
Proven huh Bryce?? RLY??? LOL. Bullshit. None of those guys at that shop wouldever say anything like that either...
2 cars in this thread alone (Jordy and Joe) made over 10-12% LESS on a run of the mill DJ 224 (The same model that the same shop uses for their high HP tuning since the packs cant take it) than they did on that thing. 2 others confirmed it as well. Most recently, Alex.
You never did really get it.
Old Feb 17, 2011 | 07:11 PM
  #115
Axix24's Avatar
- Derek
^^^ out of curiousity, is this with the boost controller enable or disabled? if so, at what duty % was the bc at???
Old Feb 17, 2011 | 08:26 PM
  #116
jnv255's Avatar
Old Feb 18, 2011 | 04:18 AM
  #117
D-Rob's Avatar
The top port of the wastegate was open to the atmosphere, so boost controller was not even hooked up, it was working off wastegate spring alone.
Once the solenoid was hooked up, it required a solenoid lookup table that had a ton of duty in the middle, and trickling down to zero up top to flatten the boost curve.
Axix, this has been covered elsewhere.
- Derek
Old Feb 25, 2011 | 02:17 AM
  #118
djxtreme808's Avatar
I made 499hp @ 16lbs on pump. backed it down to 14lbs and made 448. this was on a ls vtec 84mm with precision sc6262
Old Feb 25, 2011 | 08:55 AM
  #119
blackeg's Avatar
i like this thread. the more i read the more im realizing my goals are very attainable. id like to make at least 450 whp safely on 93, 84mm gsr with a t3 60-1. i'd just like to make enough power to have a good shot at cracking into the 10's. i guess my big concern for pushing higher hp on pump is the consistancy of the gas..... i know i always fill my car up at the same station at the end of my street, and that will also be the gas i use when i tune it on the dyno.
just to add, my car made 425 on 18 psi no issues last time it was on the dyno
Old May 27, 2011 | 03:45 PM
  #120
timothyjherbert's Avatar
I made 513whp@16.8psi 93oct on Precision tunings dynojet. Initially I took my 14.5psi tune from evans that showed 492whp but that was on the dyno packs and ran that tune at Precision with everything the same and it showed 423whp. So that being said IDK how or if you would want to extrapolate those numbers but that would put my car at roughly 580whp@16.8psi on Evans dyno packs.Obviously estimated.....I will be going back to raise the boost with a new knock sensor and possibly race gas...trying to beat my best 608whp@18psi on race gas.
ls/vtec, head games ported/polished head,manley rods, cp pistons(83mm) Sleeved block, custom, forward facing manifold, dual tial 44's,edelbrock intake,sk2 tb, hondata s300 bosch 044 fuel pump, aem fpr, custom 3" evans dp
PT67 t3/.82
Old Jun 28, 2011 | 06:51 AM
  #121
2ltrgsr's Avatar
i made 509whp 335lbs torque @18psi with a little boost creep
bone stock head and itr cams with 84mm sleeved block(b18c) 10:1 comp.
sc6162 w/.82 a/r......WITH A/C AND ITS RHD!!! lol
http://www.youtube.com/watch?v=dVMev...&feature=share
boosted crx-r
Aug 29, 2009 05:12 PM
garage16.ca
Feb 23, 2009 01:49 PM
LudeToAHatch
Dec 24, 2007 01:02 PM
fanta!
Jul 6, 2005 08:13 AM
