highest hp on pump gas
Originally Posted by extralargenog
Its not the open deck that owns hondas, its shitty piston design... The Hs sleeves are stong as [freak], but the FRM wont polay with forged internals.
also explain your reasoning that hondas have a shitty piston design.
Originally Posted by hatch34
what up spiker its joe, im coming after you buddy hahah just playing
Tony... Ring placement on Honduhs suck ***... Engaging you is a waste of energy... Go cite some **** youre going to regurgitate from elsewhere... Figure out why for yourself. Tryiong to explain **** to you is a waste of my time.
So... WHat are YOU making on pump gas??? Otherwise STFU
KTHXBYE
Modified by extralargenog at 11:43 PM 11/11/2008
476 whp / 323 tq @ 17 PSI
Different octane is available as "pump" for different areas. In socal, our highest octane pump gas available at local gas stations is 91. I am making 476 whp, 323 tq @ 17.4 PSI on a GT37R fully built GSR with Golden Eagle HD sleeves (closed-deck design) on 91 octane and running strong
about half the station here have cut back to 91, mobil and some others still have 93. e85 is on the pump here everywhere though and cheaper than anything.
you can find some 110 on the pump a short drive from here.
Theres a station up ghere CENEX that has 94 on the pump... Ive never run it, but it costs no more than 92... Im thinking its got a **** ton of ethanol in it...
KTHXBYE
KTHXBYE
besize honda theft in my area is way to bad. oh an thanks for random flame attack out of nowhere i really do appreciate it
. also the fact that you think motors that are built for N/A from the factory should have thicker ringlands to accomendate FI is just really genious on your behalf.
You = fail.
Fitting.
OBVIOUSLY you cant read... I didnt say thicker ringlands anywhere dumbass... Youve been a douchebag since day 1, looks like not only are you improving on that , but that you lack fudamental skills keeping you from making any progress in becoming relative here.
Your mom must be proud.
Oh by the way broke *** college kid... ITS [freak]ING GENIUS. Genius.
Proof you should drop out and fail merely here. Quit wasting your money on school..... Your knowledgabilities, basic education and VAST experience building **** thats fast on ANY platform surely surpass mine.
KBAI
KTHXBYE
Modified by extralargenog at 10:10 PM 11/12/2008
Fitting.
KBAI
Trying to explain **** to you is a waste of my time.
Originally Posted by tony413
NLR ramping boost feature FTW
the dart block from what i was told is not worth a dime.
And lastly, no one is crazy enough to have a Dart block, and log the coolant temps on the dyno, and a probe on the cyl head and one at the lower block plug to check to see how well coolant is circulating and transferring heat. I don't have proper data to display, but I have scattered data which shows every sleeved block I have tuned on my dyno would run hotter at the head, but cooler at the block; but the head stays hot for so much longer on a sleeved block. The pattern is there, but I am lacking the 100% homerun by swapping a sleeved block into my Integra and do a direct temperature comparision...lol The info I have currently does tell me a lot already though.
And finally, I haven't ran into a sleeved block locally that has as much mileage on the motor as mine yet. I was one of the only guy who had a built Honda good enough to drive a fully built block as my daily driver for 5 years in a row and still showing up to work on time. My motor now has about 60000-61000miles on it, and it was my primary weekend/track car as well before I had the Supra since late '06.
I think it's worth every friggin dollar for the Dart when big money is at stake for a full motor build, and I know my Dart block will never fail me.
isnt your dart block sleeved ?
i have yet to see any company offer a solid block like the 4g63. also how much hotter is a "xxx" sleeved block compared to a dart ?
oh an whats up with your web site i cant get on
Modified by tony413 at 2:51 AM 11/13/2008
i have yet to see any company offer a solid block like the 4g63. also how much hotter is a "xxx" sleeved block compared to a dart ? oh an whats up with your web site i cant get on
I'd say there are hundreds if not thousands of people with sleeved blocks that DD their cars and have no problems whatsoever. Its all in the parts, build, and tune of the a car that makes or breaks it IMO, and in my experience. I'm not saying the dart design might not be stronger, but I'm personally willing to bet my motor will last me tens of thousands of miles because I put the right parts, time, and a great tuner with my build.
GE HD sleeved block here not 1 issue at all... Using OEM HGs No coolant pushing either. Not one bit. OVer 10K Beaten profusely... Half the time at over 20 PSI on good gas.
I have seen video of one Benson block "Leaking" pressure. They were going nuts trying to find out what was going on, it only happened when the block was hot.
When the owner showed me the tape he asked that I didnt get into the particulars, and he still uses Dan (benson) for sleeving in additon to GE. MOST sleeve stories (bad ones) are regurgitated heresay however.....
It was from a semi local shop here in the NW. Its the only Benson mishap Ive heard of.... BUt ALL manufacturers have to have 1 or two.... **** happens. Benson of course took care of thew issue. He uses Proprietary Darton manufactured sleeves.
GE or BEnson are the only way Id go.
I am not knocking on any sleeving companies at all, although all the companies mentioned above had problems. The only issue being up here in Canada is the lack of support from sleeving companies because shipping the block back and forth across the border just isn't cost effective in fixing a potential problem that could be minor yet becomes worse over time. Unlike guys in the U.S., any problem can be easily solved because the shops are much closer and shipping is easy. So what I have personally seen over the years are sleeved blocks that never run right. Local shops doing the sleeving isn't any better either. Like I mentioned, aside from serious problems like severe leakage or sunken/shifted sleeves that has to be dealt with immediately, the minor stuff still remains but people still continue to drive the car as-is. Whether it is mysterious coolant loss, or a limited lifespan on a headgasket, or air keeps entering the coolant system over time. The stock sleeve craze is pretty retarded here, with guys trying to pushing over 450 WHP on stock sleeves on pump gas just to avoid sleeving a block and potential headaches.
ive made 425 on pump with a b16/gsr combo motor. timing was safe and afr was rich. 18 psi off a 60-1. the motor has seen just about 10k miles, 30 track passes and around 10 dyno pulls. i coulda got that setup to around 440 on that boost level with a more aggressive tune. i wouldnt want to push it too far, it leaves very little room for any error or mishap. plus as people have been saying, unless you've got nice boost control, its real useless on the street. with a regular michelin tire my car would spin all the way through 3rd if i romped it hard
