Boost creep/spike/smth: Tial WG 44mm.
Hey Fellow H-T's,
I have an build b16 with t3/60-1 turbo. Currently @ 7.4 psi @ 267whp. See my setup @ http://www.cjperformance.com
My tial wg has a 0.5 bar spring. But after looking @ my datalogs i see that 7500rpm> my boost creeps up to 8.1 psi.
-full-race manifold(prostreet).
-tial wg 44mm.
-My dumptube is besides my exhaust till after my block.(no exhaust gasses in my engine bay)
-3" downpipe
-2.5" exhaust
-Vacume hose comes from edelbrock mani to an 3 way spilt.
>1 going to my wastegate
>1 going to my bov(backdoor IC)
>1 going to a boost solenoid which is disconnected)
I can try to remove boost solenoid and then put a 2 way spillter just wg and bov.
But i like to hear comments what could be the problem
Thanks
CJ
Modified by calvinPGMFI at 6:02 PM 3/5/2006
-tial wg 44mm.
-3" downpipe
-2.5" exhaust
Thanks
CJ
i ♥ my honda
Global Mod
Global Mod
Re: Boost creep/spike/smth: Tial WG 44mm. (calvinPGMFI)
What you are explaining sounds pretty normal at low boost. Just tune for it up top, you wont have a problem.
But if you are having the exact same issue at higher boost you might have another issue.
Re: Boost creep/spike/smth: Tial WG 44mm. (White Smoke)
yea even really large wastegates will have trouble with boost creep if you have a larger turbo thats on low psi since so much exhaust is diverted through it instead of the turbine.
Calvin, That's a pretty normal creep for a setup like yours. I wouldn't worry to much about it. One more reason I'm not crazy about the wastegate placement of most of the turbo manifolds being used.
Re: Boost creep/spike/smth: Tial WG 44mm. (MindEracer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MindEracer »</TD></TR><TR><TD CLASS="quote">One more reason I'm not crazy about the wastegate placement of most of the turbo manifolds being used.</TD></TR></TABLE>
What would optimal placement be for a wastegate?
Re: Boost creep/spike/smth: Tial WG 44mm. (XES)
With a ram horn manifold, the only way to totaly eliminate low boost creep is to run 1 really big gate or 2 gates, if there was an optimal wg placement on a ram horn manifold low boost creep on a efficient turbo setup wouldn't be a problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XES »</TD></TR><TR><TD CLASS="quote">What would optimal placement be for a wastegate?</TD></TR></TABLE>
As explained above.. I love your lude..
I don't wan't to jack Calvin's thread, but here is a short thread on the subject of ram horn vs sidewinder wastegate placement: http://forums.evans-tuning.com...ight=
Modified by MindEracer at 1:23 AM 3/6/2006
V-SPEC 1
02-19-2013 07:43 PM
