help w/ boost
Old Mar 11, 2003 | 01:12 PM
PolosportZ81's Avatar
New User
Default help w/ boost
i'm running the greddy turbo kit at stock boost, should be at like 5-6 psi, but this morining i was getting 2 psi on my guage, and then this afternoon i was hitting 4 psi..... any ideas what could be wrong?? i checked all the vac lines and all the pipes
thanks!
oh yeah i dont think its the weather ...
Old Mar 11, 2003 | 01:50 PM
New User
Default Re: help w/ boost (PolosportZ81)
any ideas?
Old Mar 11, 2003 | 02:37 PM
Gravy's Avatar
you might have boost leaking from somewhere check everything.
Old Mar 11, 2003 | 02:39 PM
New User
Default Re: help w/ boost (GRTechnologies)
yeah i'm pretty sure i have a boost leak....i check all the vacum hoses...everything seems fine, what else should i check?
thanks
Old Mar 11, 2003 | 04:25 PM
New User
ttt
Old Mar 11, 2003 | 04:27 PM
bottlefedb18c1's Avatar
if you have a intercooler check if anything hit it and put a hole in it
Old Mar 11, 2003 | 05:31 PM
New User
Default Re: help w/ boost (boostfedb18)
if the fins were damaged, would that affect the boost?? i'll check for holes in the morining but i dout thats it....
Old Mar 11, 2003 | 06:41 PM
Gravy's Avatar
check your intake for any leaks to. the gasket can be broken and boost can leak through their
Old Mar 12, 2003 | 11:27 AM
New User
what can i use to check for boost leak? i heard there was something i can do or use, anyways intercooler is fine, vac lines are tight, intake is tight, this afternoon my guage was reading 0-1psi
boostless
Old Mar 12, 2003 | 12:38 PM
5thgencivic's Avatar
What kind of boost gauge are you running? Can you feel the car losing boost? And is your actuator hooked up to the turbo or vacuum source?
[Modified by 5thgencivic, 11:41 AM 3/12/2003]
Old Mar 12, 2003 | 01:46 PM
swlabhot's Avatar
Check your wastegate if you're running an external one and make sure its not leaking....
Check your BOV mounts..
Old Mar 12, 2003 | 03:35 PM
New User
Default Re: help w/ boost (swlabhot)
thanks for the replys, its an autometer liquid filled guage, no its an internal wastegate, i got one of those leak testers from a friend, i'll run soapy water on all the lines tomorrow
once again thanks guys!
accord99power
Sep 8, 2009 06:35 PM
trigger_time
Aug 25, 2009 12:38 PM
Po0r LiTTle CoUpe
Oct 15, 2005 10:39 PM
crucial si
May 31, 2003 08:46 PM
snake01
Jul 28, 2002 09:50 PM
