Hurry help!!! Boost problem
Old Jul 28, 2002 | 03:41 PM
snake01's Avatar
Default Hurry help!!! Boost problem
alright I got a drag III kit on a si we bolted it up and we took it for a spin broke it in a little bit. But anyways the first time we got on we felt boost. Now we feel no boost It sounds like the turbo is trying to spool but then it never makes boost we dont have a boost gage yet. Idle is fine and there doesn't appear to be any vacuum leaks. Right now this car is damned slow.
Any ideas?
Old Jul 28, 2002 | 03:43 PM
PreIudeSI's Avatar
From: California ... Beauuutiful, so cal, pwnited States
Default Re: Hurry help!!! Boost problem (snake01)
Sounds like there might be a leak somewhere in the plubming. Make sure all the silicone connectors are working properly. Then check the waste gate, make sure thats working properly. check the BOV, etc
Old Jul 28, 2002 | 04:34 PM
Pengo's Avatar
Default Re: Hurry help!!! Boost problem (PreIudeSI)
Yea, check the pipes, esp around the intercooler. this was the problem with my friends car when it boosted the first time out, and then stopped. check the wg too and make sure the BOV isnt leaking
Old Jul 28, 2002 | 04:48 PM
Kamin's Avatar
Default Re: Hurry help!!! Boost problem (Pengo)
im willing to bet its an intercooler pipe.
those come off all the time
Old Jul 28, 2002 | 04:52 PM
h0mesk1let's Avatar
id go ahead and get a boost guage before things get ugly
Old Jul 28, 2002 | 04:56 PM
PrecisionH23a's Avatar
Default Re: Hurry help!!! Boost problem (EGb18cT)
also check the check valves.
Old Jul 28, 2002 | 05:08 PM
slid-n-rag's Avatar
I had the same problem with mine and the only thing that was wrong with it was the piping blew apart....But you need to get a boost gauge and a air/fuel soon
Old Jul 28, 2002 | 08:01 PM
bottlefedb18c1's Avatar
i had the same problem the first night i took my car out with the kit on it was the conection from the throtalbody to tre intercooler pipe was off check all your pluming
Old Jul 28, 2002 | 09:50 PM
Flamenco-T's Avatar
Default Re: Hurry help!!! Boost problem (turbogsrb18c1)
does it threw any code ? if it's the missing link, it'll threw a code..
check your all your lines and connectors
Ultra EK9
Feb 13, 2011 06:48 AM
Po0r LiTTle CoUpe
Oct 15, 2005 10:39 PM
crew08 (girlygirlracer)
Oct 13, 2005 07:58 PM
crucial si
May 31, 2003 08:46 PM
PolosportZ81
Mar 12, 2003 03:35 PM
