Head Lifted!
Old Jan 22, 2012 | 08:34 AM
  #26
JDMCIVIC919's Avatar
Default Re: Head Lifted!
I havnt had time to take the head off but did a compression test and got 120 in cylinder one an 0 in the rest...
Old Jan 22, 2012 | 09:38 AM
  #27
SiRCiviC94's Avatar
kaboom
Old Jan 22, 2012 | 09:56 AM
  #28
Slacker93eg's Avatar
10 Year Member
/thread
Old Jan 22, 2012 | 10:27 AM
  #29
Yea going to take the head off tonight and see what happened. Probably cracked a sleeve. Thanks for everyone for the help. Time to build this motor.
Old Jan 22, 2012 | 10:28 AM
  #30
brixcivic's Avatar
like he said KABOOOOOM!! u live and learn.. pull it all apart and hope you can salvage something.. but looks like u gonna need a new motor.. good luck
Old Jan 22, 2012 | 10:52 AM
  #31
AlexDphoto's Avatar
post pictures of the block when you pull everything apart. should be an interesting sight but not an uncommon one when **** like this happens.
Old Jan 22, 2012 | 11:00 AM
  #32
racebum's Avatar
Originally Posted by Vinnie909LSVTEC
So i take it u dont have a BOOST Guage? so who knows how much u were boosting!! and yes stock map sensor stop reading at 11psi but it wont boost cut off at 11 unless ur tuner told it to!! so more then likely u spiked up words around 20 and who knows what happen! gotta pull the head and see whats going on! good luck! my advise, dont install a boost controller unless u have a guage and know what ur setting it at!
sounds like what happened.
you had a tune to 11psi {maybe} beyond that your motor is getting 20+psi on a tune designed for 11.
tear it apart and see what you melted. would be kind of surprising if you didn't melt a piston, fracture a sleeve, or frag rings
Old Jan 22, 2012 | 12:11 PM
  #33
Yea i learned my lesson.. I must of installed the MBC wrong. Anyone know how the forge unos mbc goes? My motor blew after i installed this cuz on the way to pick up te forge i was on it a lot and nothing happened. The first pull i did with the mbc n kaboom.. I have the wastegate going to the sideport on the mbc n the bottom going to the turbo. Thats how it was on their website, and the mbc was only turned about 5 clicks.
Old Jan 22, 2012 | 01:08 PM
  #34
SovXietday's Avatar
From the turbo into port number 2, then port number 1 to side port on the wastegate.
Feed line ALWAYS go to the long side port on an MBC, you are pushing a spring and springs need a place to expand/contract (IE, a long tube).
Old Jan 22, 2012 | 01:41 PM
  #35
I had it installed right. Maybe 6 clicks was too much for the car... Hopefully i can get the head off tonight after work n inspect everything. If i drain the oil and it has coolant in it that means i cracked the sleeve right?
Old Jan 22, 2012 | 02:15 PM
  #36
AlexDphoto's Avatar
If youre not tuned for it, any click can be too much for the car.
do you have any higher boost settings other than what your car is tuned for?
Old Jan 22, 2012 | 02:55 PM
  #37
TheShodan's Avatar
Moderator
Originally Posted by SPOOLINmatt
does a head really lift? I just can't see it phyiscally lifting from the pressure the turbo is adding on top of the immense pressure of combustion. usually its just the headgasket on its way out anyways.
I've experienced "head lift". the increased cylinder pressures can work against the cylinder head causing it to literally "rise" enough for it to slip out. That typically happens with an incorrect headstud install or a situation in which the headstud "stretched"..
Its indeed possible, even though highly improbable.
Old Jan 25, 2012 | 06:37 PM
  #38
Took off the head tonight and found i cracked the sleeve in cylinder 2. Big crack going all the way down. I still dont understand how i got 0 compression in the other cylinders with no cracks.
Old Jan 25, 2012 | 07:17 PM
  #39
TheShodan's Avatar
Moderator
Either way, its a wrap. From now on.. NO CLICKs when your rebuild it. I've seen car blow up from 1psi of positive pressure regardless of turbo size. Increased cylinder pressure is increased cylinder pressure
Old Jan 28, 2012 | 10:46 AM
  #40
Ok so someone is selling a completely stock b16 block that is coming out of the machine shop soon from a fresh oem rebuild. To pistons, rings, hone, bearing, mirco crank, etc. Should i get another block like this or just go ahead n build one for my turboed car. Im still going to be boosted so im going to boost again on this b16 block if it get it. Was just wondering if its dumb to get a stock b16 block with 0 miles n turbo it right away.
Old Jan 28, 2012 | 11:11 AM
  #41
Ek4 SiR's Avatar
I had the same exact situation that happened to me about to 3 years ago..blew white smoke and everything and coolant everywhere..took the the head off and sure enough I cracked a sleeve.
Oh yea mine happened while it was getting tuned it was set at 16 psi spike to 24 and kabooom!
Old Jan 30, 2012 | 07:14 AM
  #42
BigMike0147's Avatar
^^^ Exactly why I spent more to go with Neptune RTP. Boost cut FTW!!
Freshdot
Sep 16, 2010 03:30 AM
Turbocivic94
Jun 19, 2009 10:28 AM
dsturch1
Mar 25, 2008 06:16 PM
DelSolMike
Jun 6, 2006 03:57 AM
Ri5e
Sep 9, 2002 01:13 PM
