Coolant pushing through reservoir
Old Jun 19, 2009 | 05:55 AM
Turbocivic94's Avatar
Default Coolant pushing through reservoir
It only happens when car is under boost. Motor has around 500 miles on it. Temp gauge stays normal and never goes up. I'm thinking its headgasket.
What do you guys think?
Old Jun 19, 2009 | 06:00 AM
Wopsicle69's Avatar
Default Re: Coolant pushing through reservoir
headgasket or cracked sleeve
Old Jun 19, 2009 | 06:04 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
headgasket since it happens under boost. Head is lifting just enough to introduce air in the system when you boost.
resurface the head and a new headgasket. make sure your arp head studs are even.
Old Jun 19, 2009 | 07:20 AM
Thats what I thought, just wanted to get other people's opinions. Thanks
Old Jun 19, 2009 | 07:26 AM
batboyvaj's Avatar
make sure you are tq'ing the arp's to 80ft/lbs. I think those are the new specs with moly lube.
Old Jun 19, 2009 | 07:52 AM
twkdCD595's Avatar
what they said, headgasket/ head lifting under boost... i had a similar issue which was doing the same thing.
Old Jun 19, 2009 | 08:04 AM
Bseriescivic5's Avatar
unlikely to be cracked sleeve if only observable during boost. Warped head? In either case what the rest of these guys said, new HG, Get head checked and re-tq. report back if problem persists.
Old Jun 19, 2009 | 09:08 AM
Cool, gonna take the head off and get it resurfaced. I didnt resurface the head last time I had it off so that could be the problem.
Get to put the rods and pistons in while I have the head off.
Old Jun 19, 2009 | 10:28 AM
H.A.R.T B18C1EG6's Avatar
i always resurface the head once taken off. just a habbit i guess. just resurface with new gasket/studs and your golden.
aho
Dec 15, 2007 09:24 PM
hangac1093
Dec 12, 2006 02:38 PM
White_EK49
Nov 6, 2005 10:22 PM
VTgringo
Dec 20, 2003 01:11 PM
Ri5e
Sep 9, 2002 01:13 PM
