GT30R oil return problem - vertical enough?
The guy that's had my car for almost 2 1/2 years has FINALLY started to work on it again, but that's another story. The problem now is that we can't clock the turbo enough to make the oil return completely vertical, because the oil feed fitting on the other side hits the manifold when we turn it. I've got an ATP .035" oil restrictor, in addition to a low profile Goodridge 90° -4AN hose end. There's nothing else I can do. Please take a look at the attached pictures and let me know if this is good enough. The second picture is looking straight up. My only other option is to switch from -10AN to -12AN and open it up a bit, but a -12AN fitting might give me clearance problems on the turbo itself. What do you think?
