Greddy Type-s single spring mode
Old Aug 5, 2009 | 03:47 AM
TURKISHFORCE's Avatar
Default Greddy Type-s single spring mode
hi from germany..
what this means single spring??
when i build (changes )this (spring)is the blow off vale louder than before it, ore open faster in low psi line .
and is this mode only for EVO not for honda turbo
better try change it ore not???
info..
http://www.evomoto.com/tech_info.php?tech_id=7
help..
thanks..
Old Aug 5, 2009 | 04:32 AM
dpetro1's Avatar
Default Re: Greddy Type-s single spring mode
Just like the write-up shows. you take apart the BOV and take one of the two springs out. this puts less pressure on the diaphragm making it easier for the BOV to open. this may help to reduce comopressor surge at lower psi. the part about stalling does not apply to hondas since we run MAP sensors.
this may be helpful if you are having surging issues but other than that it really isnt needed. also it might cause the bov to be more prone to leaking at higher psi
Old Aug 5, 2009 | 07:10 AM
tanks for info..
lsv_ 973
Jul 11, 2011 05:17 AM
bubskie
Jan 21, 2011 03:27 PM
Integra21
Jun 11, 2005 04:47 PM
bluels-t
Oct 20, 2004 07:29 AM
AF-b16a1
Aug 11, 2004 11:30 PM
