BOV spring??
Old Jun 11, 2005 | 01:37 PM
Integra21's Avatar
Default BOV spring??
would it be possible to swap out the spring from a Greddy Type S BOV and put it in their new Greddy Type-RS??
the RS is a slightly larger BOV - 37mm vs 40mm
thanks
Old Jun 11, 2005 | 02:44 PM
Integra21's Avatar
Default Re: BOV spring?? (Integra21)
is this possible?
Old Jun 11, 2005 | 04:20 PM
wantboost's Avatar
Who is Mr Robot?
why would you want to do that? type s spring was designed for a 37mm valve.. the rs is a 40mm vavle, the pring in the rs should be a larger diameter.
why even bother with it?
Old Jun 11, 2005 | 04:26 PM
Integra21's Avatar
Default Re: BOV spring?? (wantboost)
because i just bought a RS and it will not blow off, no matter what setting i have it on. and yes, it was installed correctly.
the stronger spring is the cause of this. i am only running 7psi of boost so it wont blow off
Old Jun 11, 2005 | 04:28 PM
wantboost's Avatar
Who is Mr Robot?
where have you tee'd off for a vacuum source for the bov? try a stronger vacuum source, loosen the adjusting bolt all the way.ts not really a stronger spring, only one with a larger diamter, not height or coils, therfore the spring rate shouldnt change
and you said it yourself you heard a long drawn out whistle... thats the sound it makes at low boost levels, trust me
Old Jun 11, 2005 | 04:36 PM
Integra21's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">and you said it yourself you heard a long drawn out whistle... thats the sound it makes at low boost levels, trust me</TD></TR></TABLE>
yes but with the type s, the whistle occurs after it blows off
Old Jun 11, 2005 | 04:40 PM
wantboost's Avatar
Who is Mr Robot?
at high psi levels, the rs sounds like a rfl. at low boost is whistles. you just dont like the way it sounds. all of the sounds clips i have seen of low boost turbo kits with a type-s or rs just sound like a spacebird.
Old Jun 11, 2005 | 04:44 PM
Integra21's Avatar
the thing is it makes no "space bird noise" while shifting there is NO sound in between shifts
Old Jun 11, 2005 | 04:47 PM
wantboost's Avatar
Who is Mr Robot?
there should be a faint whistle, not a pronounced one.
also remember the rs has the holes machined on the discharge so its going to draw in surrounding air. which will quiet down the bov some, making more of a woosh sound at first then a slight whistle. 7psi i wouldnt expect any bov to be loud, unless its an hks or rfl
bubskie
Jan 21, 2011 03:27 PM
jacob4lester
Feb 15, 2010 05:30 PM
ITRICED
Mar 4, 2009 09:33 PM
ZhaGg
May 16, 2005 12:07 PM
knightnam
Jul 5, 2004 09:41 AM
