greddy profect 2 help*
Old May 19, 2010 | 07:17 PM
thegatekeeper14's Avatar
Default greddy profect 2 help*
ok so i tune on friday but i have no idea how to wire up my profect 2 with my exernal wastegate.
one question i have is do i need a vacuume source before the throttle at all? if so why?
diagrams will help a ton.
Old May 20, 2010 | 06:25 AM
dpetro1's Avatar
Default Re: greddy profect 2 help*
see page 10 for external wastegate setup. you should be using pre-throttle pressure sources.
http://www.greddy.com/img/PHP/products/pdf/682.pdf
basically,
top port of wg to COM port on solenoid
side port of wg to pressure source
NC port to pressure source (you can tee into side port line)
your boost controller doesnt need vacuum. its controlling boost so it only needs to see boost.
for the in-cabin unit you need to run a vac line w/ inline filter (to the intake manifold), wire the power and ground, and run the wiring harness to the solenoid.
if you have a fitting on the compressor housing then you are good to go. if not then you can tap one or tap a charge pipe.
Old May 20, 2010 | 07:32 AM
TheZooKeeper's Avatar
Followed the book and it was cake!!!! I leave that thing in my glove box
Old May 20, 2010 | 08:20 PM
ill look at it, some of the local shops say pre throtle isnt the biggest deal.
1320king
Jul 8, 2013 05:47 AM
boostek9
Jun 9, 2010 06:52 PM
1cammerjammer
Oct 22, 2009 10:04 PM
B18del-turbo
Mar 16, 2005 08:02 AM
integRated109
Jul 17, 2001 05:00 PM
