s300 Boost Controller MAC install help?
Old Jun 8, 2010 | 07:00 PM
boostek9's Avatar
Default s300 Boost Controller MAC install help?
I have searched and no luck on a visual.
I have my controller wired up and ready, I just want a pic of someones installed with the vaccum lines.
MAC solenoid is labeled, 1=manifold? 2=top of wastegate? 3=filter or left open?
Thanks for the help
Old Jun 8, 2010 | 08:38 PM
MikeySpec's Avatar
Default Re: s300 Boost Controller MAC install help?
1 goes into vacuum and the side of the wastegate. Just imagine if you had a vacuum line ran into the side of the wastegate to the intake manifold. You'd be basically tee'ing port 1 into that line.
2 goes directly to the top of the gate.
3 stays open and usually has some kind of filter/ open fitting on it.
Old Jun 9, 2010 | 04:25 PM
portenio78's Avatar
here a good diagram:
http://tunertools.com/prodimages/AEM...st_30-4350.pdf
Old Jun 9, 2010 | 06:27 PM
boostek9's Avatar
excellent, thanks
Old Jun 9, 2010 | 06:52 PM
Turbo-LS's Avatar
everything is done properly. just strt out by doing duty cycle only and go up a little at a time and recored how much duty is equal to what boost pressure. then input it into the graph below so you can do boost by gear which is great. helps out a ton with traction in lower gears
zach1288
Jul 8, 2010 02:39 PM
Boost3d22
Dec 19, 2004 09:54 PM
gofastjdmcivic
Apr 28, 2004 04:29 AM
20lb.teg
Sep 14, 2002 02:28 PM
