1 or 2 vacum lines 4rm da wastegate?
I have one vacuum line from the top of the waste gate running to the fpr and intake manifold theres another place 4 another vacuume line on the side should I run another pressure source to it or leave it open ?
Mr. Badwrench
Re: 1 or 2 vacum lines 4rm da wastegate?
fixed it for you. took me a minute to figure out what you were saying.
the top port is for a boost controller. if you have no line going to the bottom port, you have NO BOOST CONTROL.
if you want to run wastegate pressure only, the vacuum line from the fpr (although i would run a dedicated line from the turbo, or atleast a vacuum manifold) needs to go to the bottom port. the top port is for a boost controller.
Alrite so I have the top to a boost controler so all I would need to do is run the other port on waste gate to the turbo
