Fuel Question??
Old Nov 3, 2001 | 12:59 PM
BoostingGSR's Avatar
Default Fuel Question??
Are Rc 310s injectors big enough for a Gsr with a drag gen 2 with Hondata stage3B?? If not, what size should I get??? and do I need a FPR with the Hondata and the injectors?? Thanks in advance.
Old Nov 3, 2001 | 03:25 PM
ekb18c's Avatar
Default Re: Fuel Question?? (BoostingGSR)
The biggest info you forgot to mention is how many psi's you want to run?
Old Nov 3, 2001 | 05:00 PM
Default Re: Fuel Question?? (ekb18c)
Opps....i'm planning to run between 10-12 psi daily. This is on a stock motor.
Old Nov 3, 2001 | 05:09 PM
ekb18c's Avatar
310 CC is fine for now. If you are planning to run 10psi. however if you want to run any more then 10 psi i would suggest you run a fuel management system (Haltech, DFI, SpeedPro) OR else you may blow up and then you will be kicking yourslef. You should also have a FMU (vortech or paxton FPR). Stock ecu can only handle up to 13 psi safely
HTH
GSROWNSU
Feb 4, 2007 09:17 PM
shervin
Apr 16, 2005 07:16 PM
Cezilla
Mar 28, 2004 08:21 AM
CaptainMorgan
Dec 25, 2003 09:51 PM
NeXtLeVeL_TyPe_R
Oct 4, 2001 08:31 AM
