quick injector question
Old Apr 16, 2005 | 04:49 PM
shervin's Avatar
Default quick injector question
im going to be running fmu, and with a 7 or 8 psi wastegate spring, im changing fuel pump, and getting fpr do i really need to change injectors , or is it something it can be done later on, oh btw the motor is a b18c(jdm gsr)
Old Apr 16, 2005 | 05:09 PM
s2kdre's Avatar
Default Re: quick injector question (shervin)
you cant use bigger injectors with an fmu, cause you need something to control them at idel
Old Apr 16, 2005 | 05:10 PM
s2kdre's Avatar
Default Re: quick injector question (jdmhonda)
fmu is vaccum driven as soon as the intake sees boost it dumps in fuel 12 psi per 1 pound of boost, its gonna be rich as it is with stock injectors.
Old Apr 16, 2005 | 06:40 PM
shervin's Avatar
so is it 100% safe to run stock injectors under 10 psi?
Old Apr 16, 2005 | 06:52 PM
SSBPGSR's Avatar
Default Re: (shervin)
i wouldnt run 2 psi with an FMU personally. but i wouldnt push it to 10 esp with a higher comp JDM motor
Old Apr 16, 2005 | 07:16 PM
shervin's Avatar
well im going to run 7 psi.
Bimmerman
May 3, 2005 05:51 PM
honkey2fly
Apr 22, 2004 11:50 AM
GOLDBERG
Apr 13, 2003 05:16 PM
Rah Rah
Feb 24, 2003 06:03 PM
Giuseppe
Oct 10, 2001 09:23 PM
