SURVEY -- Whats the max psi any you guys have run on a b18c5
Whats the daily/max psi any of you guys have run on a B18C5 motor with stock internals, stock injectors, 12:FMU, DRAG provided fuel pump & no further AFC's or ecu upgrades or anything like that.
I would like to know where i can start off with my Type R with DRAG gen 3 kit
Thanks in advance for replies
Re: SURVEY -- Whats the max psi any you guys have run on a b18c5 (NeXtLeVeL_TyPe_R)
I have run my Drag 3 setup at 8 psi for over a year now with no problems. I am going to run more now that I have the J&S installed. The J&S might be too sensitive for a turbo itr and I am trying to determine if I should send it back to get the unit desensitized.
well if i still stick to my plan to rob a bank by the end of this year to afford turbo i plan on 6-8psi daily.. but wonder if i'll be able to hit 10 once in a while?
stock ITR motor, headgasket, injectors, hondata.. i want to run this set up as long as i can.. so once the rings go.. then i'll upgrade the bottom.
InfamousRS
01-18-2002 01:45 PM
