Fuel Pressure Problem... Help...
Old May 22, 2004 | 09:56 PM
DRIVENRacing's Avatar
Default Fuel Pressure Problem... Help...
Ok, i am running the usual fmu, inline fuel pump missing link afc to tune... everything is instaled, and when the car cranks my fuel pressure gauge shows 20 psi... car ran 55 when it was NA... i would think car would lag bad or sputter at 20 psi, but it runs and sounds fine.. havent hit boost though because im afraid something might go wrong... any suggestions/things to check? fmu is 12:1, airtex inline fuel pump.. both working properly becauyse it came of my buddies car worked fine... any ideas? thanx
Old May 22, 2004 | 10:03 PM
Pengo's Avatar
Default Re: Fuel Pressure Problem... Help... (TurboHybridEG6)
how is your fuel press gauge setup in relation to your inline? if the car runs perfectly fine i'd say you may have to move your gauge to get correct readings.
Old May 22, 2004 | 10:31 PM
Sunrise City Rider's Avatar
Your Gauge may have took a ****...
Old May 22, 2004 | 10:38 PM
nah gauge is fine.. its on the fuel filter... fuel pump is between the fuel filter and the fuel rail..any help?
Old May 22, 2004 | 10:41 PM
Well its not fine...You're running 25psi of fuel...Stock is 38 with the vacuum line on...Something is not right...Its not in an accurate position anymore...Maybe you should change your fuel filter???
silverboost
Jan 29, 2006 12:36 PM
gtcali
Mar 5, 2003 06:48 PM
accordfreak
Aug 22, 2002 05:50 AM
B20-T
Jul 26, 2002 09:40 AM
HybridCoupe
Jul 11, 2002 12:38 AM
