EGT readings lower at higher boost?
Old Jan 15, 2006 | 06:10 PM
kenbdSi's Avatar
Default EGT readings lower at higher boost?
I have a Computech EGT gauge. It has a record feature that allows you record egt and rpms. At around 7psi my egt temps are around 1350 F at WOT. I switch the boost to 11psi and I notice that at higher boost the egt temps are lower, say around 1255 F. What would be the reason for that?
Also, the Computech gauge has an additional plug for a secondary probe. Would it be a good idead to tap it into my charge pipe (after the intercooler)to monitor the ambient temps going into the motor? Just to have a general idea of things.
Old Jan 15, 2006 | 07:34 PM
Tony the Tiger's Avatar
Default Re: EGT readings lower at higher boost? (kenbdSi)
How's the air/fuel ratio?
You are probably running lean at low boost and richer at higher boost
Old Jan 15, 2006 | 07:56 PM
D@nnY's Avatar
yea what he said...
by running richer the unburnt fuel absorbs heat and you will have a cooler exhaust temp
what are you running for fuel management?
Old Jan 15, 2006 | 08:17 PM
Blaze45's Avatar
Brrraaaap!
Default Re: (D@nnY)
Different EGTs can mean a lot of different things. Vapor Trail made a good post on what to look for and what different temps can mean...
Blaze
Old Jan 15, 2006 | 08:42 PM
HamiltonRex's Avatar
Default Re: (Blaze45)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blaze45 &raquo;</TD></TR><TR><TD CLASS="quote">Vapor Trail made a good post on what to look for and what different temps can mean...
Blaze</TD></TR></TABLE>
Excuse me who? I cant seem to find that user name. And i could benifit from this info.
Old Jan 15, 2006 | 09:08 PM
Blaze45's Avatar
Brrraaaap!
Default Re: (HamiltonRex)
Search netted me 900+ posts on EGTs. Granted some were for sale threads lol.
Wheres my cookie.... https://honda-tech.com/zero...age=2
Blaze
Old Jan 15, 2006 | 11:25 PM
D@nnY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blaze45 &raquo;</TD></TR><TR><TD CLASS="quote">Different EGTs can mean a lot of different things.
hes right also....if you retard the ignition timing to much the mixture will be ignitied to late and will still be burning int he manifold ....this will also casue higherer egts
Old Jan 16, 2006 | 01:53 AM
calvinPGMFI's Avatar
Default Re: (D@nnY)
Well from experiance,
Bump up(advance) the timing see if egt drops. Go to the point it doesn't drop anymore. From that point retard 1-1.5 degrees. If your egt drops way to much you are knocking. Also check your AF with 94 octance you want something like 12:1 or 11.7:1
I hope this helps. What are you cursing egt's?
CJ
Old Jan 16, 2006 | 06:53 AM
kenbdSi's Avatar
Default Re: (calvinPGMFI)
i am running CROME. My A/f is around 11:7. At cruisng speed I hit around 1125 F at most. The probe is located on the #3 runner.
Old Jan 17, 2006 | 03:52 AM
Did you try what i said?
Sinner
Jul 31, 2004 08:14 AM
jimbob_racing
Mar 29, 2004 01:22 AM
incognitoracerr
Jul 28, 2003 05:55 PM
boostdB16a
Jul 9, 2003 04:48 PM
liam821
Feb 18, 2002 10:18 PM
