egt readings in boost
Old Feb 17, 2002 | 10:57 PM
liam821's Avatar
25 Year Member
Default egt readings in boost
What does everybodies EGT read in boost at WOT? I just wondering if my fuel (to rich to lean) is correct.
I read around 690-710c at WOT. Under 1/2 throttle and boost i run around 710-720c. When under vacuum (cruising on the highway no boost) i also run around 710c.
Does this sound about right? My EGT probe is on the 3rd runner about 1" back from the exhaust port. I have a Greddy EGT gauge if it matters.
thanks,
liam
Old Feb 18, 2002 | 03:41 AM
boosted hybrid's Avatar
Default Re: egt readings in boost (liam821)
That is the is the range of acceptable egt readings. Your air/fuel is optimal according to those readings.
Old Feb 18, 2002 | 06:15 AM
SiR Kid's Avatar
New User
Default Re: egt readings in boost (boosted hybrid)
Woooo I must be MAJOR rich when cruising and MAJOR lean when on it
Mine spikes to almost 775-800C when I'm revving high...
Cruising never goes above 400C.
Old Feb 18, 2002 | 06:50 AM
You shoot for 600-700 when under full throttle. But when just cruising around you should be alot lower. SiRkid you are in the optimal egt readings for off/on boost.
Old Feb 18, 2002 | 07:30 AM
TurbodCX's Avatar
hey guys, i am running at about 600-650 while im am cruising, and about 650-675 while boosting... so i take these readings as being lean on the bottom end and rich on the top end., i guess rich because of having a 12:1 fmu and lean because of low fuel pressure.??? some help here would be much appreciated.
Old Feb 18, 2002 | 08:00 AM
TurbodCX's Avatar
TTT
Old Feb 18, 2002 | 09:03 AM
TurbodCX's Avatar
Default Re: egt readings in boost (TurbodCX)
come on 91 veiws and no one knows??????
Old Feb 18, 2002 | 09:10 AM
JM Performance's Avatar
I hit 690 almost everytime when boosting...so I guess wer're all cool.
oh, and this is right after #1.
Old Feb 18, 2002 | 10:18 PM
liam821's Avatar
25 Year Member
Default Re: egt readings in boost (00SilverLS)
I was watching my EGT today..and cruising around town its a little lower...like 650c. Its on the freeway where its around 700c at 80mph cruising.
Its good to know that those readings are normal.
Thanks for the posts everybody...
liam
Buffs8080
Apr 25, 2007 06:23 PM
kenbdSi
Jan 17, 2006 03:52 AM
kabaroo
Jul 18, 2004 03:27 PM
incognitoracerr
Jul 28, 2003 05:55 PM
boostdB16a
Jul 9, 2003 04:48 PM
