Dyno'd the single cam
looks like it was creeping a bit up top then settling out. nice numbers.
did ur tuner try to add more fuel in the higher rpms? if he did and there was no change in the a/f, then ur fuel pump or regulator needs to be checked/replaced
I'm not sure what u guys mean by creeping but it was holding 10psi dead on. boost cut was at 10.5 and i never hit it. Goin to put a new head gasket on tomorrow even though i have been driving it without it pushing any coolant out. And i have a new clutch on the way because the stocker started slipping after 2 days. Can't wait to drive it at its full potential.
It was at 11 degrees. maybe i will have him back it off to 10. Im going to lower the boost to 8 psi untill i can build up another shortblock wiht h beams and vitarias
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 55superbeetle »</TD></TR><TR><TD CLASS="quote">Yea i know what u mean. I will have to see what i can afford when the time comes</TD></TR></TABLE>
Learn from your mistakes the first time bro! Dont make um twice. Good luck on your build. BTW. I made 324hp on the same turbo you have with the right internals.
Installed the new head gasket today. Copper spray'd it and tweaked out torquing the headstuds perfectly. Let it heat cycle a couple of times and re checked the torque. It all payed off. I've been beating the crap out of it and no signs of leakage...............yet. The old gasket wasn't blown at all. I think it was just lifting the head due to cheating by just installing one stud at a time without replacing the gasket, won't do that again
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quicksilver1689 »</TD></TR><TR><TD CLASS="quote">from the a/f graph looks like it leans out a little bit towards 6-7k</TD></TR></TABLE>
a little too much for my taste.
b00stedbyFastrax
Sep 14, 2002 09:08 PM
Nice fab work and hp numbers too
