Dyno'd the single cam
Old Oct 18, 2007 | 01:46 PM
55superbeetle's Avatar
Default Dyno'd the single cam
Setup,
Bone stock z6 with apr head studs.
T3 60 63 thunderbird turbo
2.5 inch intercooler piping
750 rc injectors
10 pounds of boost.
Leaking headgasket
The tuner did not get to finish smoothing out the air fuel because the head gasket started to leak under boost. I think im going to lower the boost because this is my daily driver. Overall I am amazed that is made this much power. Im going to put a new head gasket in it this weekend and go back so he can finish the tune. All fab was done by me in my garage winy my 30 year old tig.
Old Oct 18, 2007 | 01:55 PM
KevronsEG's Avatar
Default Re: Dyno'd the single cam (55superbeetle)
WOW looks good. I htink your BOV is on backwards. I used one back in the day and i ran it the other way.
just an idea maybe someone else can give some idea on it.
super clean though for a daily.
kevron
Old Oct 18, 2007 | 01:58 PM
Default Re: Dyno'd the single cam (KevronsEG)
Thanks
The bov is correct. I coppied the way its hooked up on a vw. It will work the other way but this way boost pressure keeps the valve shut instead of just relying on the spring pressure.
Old Oct 18, 2007 | 02:14 PM
KevronsEG's Avatar
awesome good to know
Old Oct 18, 2007 | 03:27 PM
Cyberdx16's Avatar
good #'s, what was it tuned on?
Old Oct 18, 2007 | 03:33 PM
welfarepc's Avatar
how is the exhaust manifold?
impressive numbers in deed... im jealous
Old Oct 18, 2007 | 03:42 PM
sohczcturbo's Avatar
Default Re: (welfarepc)
Wow, that's gonna be one of the most simple yet effective setups I've ever seen. Props to your craftsmanship! But what's that ziptied to the upper radiator hose? The o2 sensor? None the less, awsome numbers. What was it tuned on and can we see some pics of the down pipe?
Old Oct 18, 2007 | 04:21 PM
Default Re: (sohczcturbo)
Yep thats the o2 sensor, still need to remove it. It was disabled using chrome witch answers your question on what it was tuned on. Here is a pic of the setup on my mock up motor.
Thanks for the compliments
Old Oct 18, 2007 | 04:37 PM
Newt Dog's Avatar
Default Re: (55superbeetle)
Clean build!
Love that manifold !
Old Oct 18, 2007 | 04:43 PM
Manny86's Avatar
Default Re: (Newt Dog)
why dont you put a new hg on it
Old Oct 18, 2007 | 04:52 PM
eh3 93's Avatar
Default Re: (Manny86)
Where did you get that little flex piece for the dump?
Old Oct 18, 2007 | 05:08 PM
Tippyman's Avatar
Default Re: (eh3 93)
Clean yo oil pan son!
Old Oct 18, 2007 | 06:11 PM
B20luda's Avatar
Default Re: (Tippyman)
pretty sure thats a mock up motor...it has a hole in the block too... but maybe thats just to make sure the rods are ok...
Old Oct 18, 2007 | 06:25 PM
Default Re: (B20luda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">Clean yo oil pan son! </TD></TR></TABLE>
Learn to read... son!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 55superbeetle &raquo;</TD></TR><TR><TD CLASS="quote"> Here is a pic of the setup on my mock up motor.
Old Oct 18, 2007 | 07:13 PM
Schister66's Avatar
Man U FTW
nice setup and great power for a stock D daily
Old Oct 18, 2007 | 07:24 PM
Snailed EF's Avatar
Default Re: (Schister66)
love the setup super clean IMO nice job
SOHC_MShue's Avatar
you might want to run less timing next time. Thats probably why the headgasket popped. Impressive numbers though . Were you getting boost creep? Your torque keeps climbing at the end of the graph.
Old Oct 18, 2007 | 07:38 PM
nsxmatt's Avatar
I never really understood why people post dyno numbers where the motor didn't stay together. May just have been a weak HG but more than likely a tuning issue which is why you made that power to begin with.
Old Oct 18, 2007 | 07:49 PM
Default Re: Dyno'd the single cam (nsxmatt)
I don't think it was/is a tuning issue. I put the head studs in without removing the head and the mileage of my motor is unknown. The timing was very conservitive. Im sure after i replace it it will be fine.
Old Oct 18, 2007 | 07:52 PM
nsxmatt's Avatar
Good deal, keep us updated
Old Oct 18, 2007 | 08:53 PM
da_dude's Avatar
It's amazing what a little single cam can do. Two thumbs up for you.
Old Oct 18, 2007 | 11:18 PM
SOHC_MShue's Avatar
so was it boost creeping?
Old Oct 19, 2007 | 12:12 AM
ghostskinner's Avatar
Default Re: Dyno'd the single cam (SOHC_MShue)
what kind of wastegate is that
Old Oct 19, 2007 | 05:39 AM
twkdCD595's Avatar
Default Re: Dyno'd the single cam (ghostskinner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ghostskinner &raquo;</TD></TR><TR><TD CLASS="quote">what kind of wastegate is that</TD></TR></TABLE>
looks like an obx... "**** is good".
OP: looks like a simple and clean setup underhood.
Old Oct 19, 2007 | 06:14 AM
Autoworks's Avatar
nice clean setup
