Dyno Tuned 14b LS
Old Jan 17, 2007 | 02:22 AM
slow hatch's Avatar
Default Dyno Tuned 14b LS
Well after having to switch to OBD1 I finally got my car back from tuning
<u>Setup:</u>
B18A
OBD0-OBD1
DSM 450cc injectors
Crome Pro
XSpower manifold
14b Turbo
2.5" DP and 2.5 Crushbent exhaust
JRC FMIC w/ 2.25 crushbent hotside and 2.5 mandrel cool side IC piping
HKS bov
LS transmission
LSDmotorsports 6 puck & HDpp
OBX LSD
Thats about it.. Took the car down to the shop OBD0 w/ turboedit, but the tuner keep having glitches with the software. So he recommended me converting to OBD1 or I would be just wasting my money by trying to make turboedit to work right. So did the switch and he tuned the car for 1 hr and got these numbers. We didnt do anymore b/c I was maxing out my fuel above 6k(stock fuel pump ) So @ 8psi we got 216.18 HP & 197.82 FTlbs Pretty happy
Unfortunatly the car still still smokes underboost and is burning a little oil So I think the rings are starting to go, oh well 160k+ miles
Old Jan 17, 2007 | 04:23 AM
USDM 4G VTEC's Avatar
good job
but perhaps the guy didnt know how to really use turboedit
he probably had problems maxing out the cells on turboedit because of the fuel multipliers, so he needed to change them and then he would have had more resolution
anyways, going OBD1 is good and gives you more opportunities
Old Jan 17, 2007 | 04:39 AM
slow hatch's Avatar
Default Re: (USDM 4G VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDM 4G VTEC &raquo;</TD></TR><TR><TD CLASS="quote">good job
anyways, going OBD1 is good and gives you more opportunities</TD></TR></TABLE>
Yeah, your probably right. He mainly deals with CromePro. Oh well I had planned on converting eventually I guess sooner than I thought
Old Jan 17, 2007 | 08:57 AM
project dc2's Avatar
Default Re: Dyno Tuned 14b LS (slow hatch)
looks liek a fun car to drive. nice powerband
Old Jan 17, 2007 | 11:35 AM
Rosetta Stoned's Avatar
Default Re: Dyno Tuned 14b LS (project dc2)
What kind of car is this setup in?
If you dont mind me asking, about how much $$ do you have in this setup?
Great looking powerband.
Old Jan 17, 2007 | 11:40 AM
le0ftw's Avatar
KOBE IS GOD
Not bad how is that obx lsd doing
Old Jan 17, 2007 | 12:01 PM
Tchleung's Avatar
Looks like a great powrband!
wa that 8psi the stock wastegate setting?
Also, I'm surprised you ran outta fuel pump cause I've seen alot higher on stock fuel pump?
Old Jan 17, 2007 | 02:01 PM
slow hatch's Avatar
Default Re: (Tchleung)
Thanks guys, this setup is in my 89 dx hatchback. I lost track of how much money I had invested once I had to get a new clutch and the LSD I went pretty mild budget on everything(hint the 14b) but wanted to keep a good fuel managment. I had to buy a $250 new distributor also(couldnt find a used one) so that added up too. The OBX LSD seems to be holding up great. I went out and tested it some more just a while ago.(Two longgggggg darkies, the ebrake wouldnt hold it ) And yeah the stock wastegate spring is 8psi, it comes around 2500rpms(makes first and second fun)
Old Jan 17, 2007 | 02:06 PM
Bailhatch's Avatar
Default Re: (slow hatch)
holy tirespin machine. bet its fun...and you want more
Old Jan 17, 2007 | 02:21 PM
slow hatch's Avatar
Default Re: (Bailhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch &raquo;</TD></TR><TR><TD CLASS="quote">holy tirespin machine. bet its fun...and you want more </TD></TR></TABLE>
Haha, yeah. Was hoping to tune it for 10psi maybe 12psi, but since it seemed to be maxing out already we couldnt get anymore. With the Walboro fuel pump I plan to at least turn it up to 10psi
Old Jan 17, 2007 | 04:44 PM
HiProfile's Avatar
Nice setup, given the price & power output - on a 15yr old engine!
I was poking my nose in another boosted Integra RS thread, mainly speaking my mind about overkill components for his setup. Needless to say, yours is WAY cheaper, makes more power, and spools 600rpm faster with supposedly worse head/cams/intake.
Anyways, any boosted street honda with good power for at least 3000 rpm gets a from me. Another for a quick spool time; it will only decrease when (not iff ) you get mandrel bends everywhere and a 3" dp.
Old Jan 18, 2007 | 03:47 PM
mannyman2's Avatar
Default Re: (HiProfile)
seeing this makes me want to drop the B16 and go ls turbo...
Old Jan 21, 2007 | 07:14 PM
slow hatch's Avatar
Default Re: (mannyman2)
Thanks guys Hope to get a aftermarket fuel pump soon and head back for some new numbers on 10-12psi maybe. lol
Old Jan 23, 2007 | 06:12 AM
Diyracing2's Avatar
14b??
Thats the mitsubishi turbo ya? Says tdo5h on the side of the turbo?
Just checking cause i have that turbo and its good to see its making some decent power on 8psi...
Keep us updated.
Old Jan 23, 2007 | 06:22 AM
slow hatch's Avatar
Default Re: (Diyracing2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Diyracing2 &raquo;</TD></TR><TR><TD CLASS="quote">14b??
Keep us updated.</TD></TR></TABLE>
Yup thats the one Cant wait to see if my motor holds together @ 12psi. lol
Old Jan 23, 2007 | 06:40 AM
Diyracing2's Avatar
I have a b18c in my eg. Going to be running your setup.
How did you route the cooling lines?
Old Jan 23, 2007 | 07:27 AM
slow hatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Diyracing2 &raquo;</TD></TR><TR><TD CLASS="quote">I have a b18c in my eg. Going to be running your setup.
How did you route the cooling lines?</TD></TR></TABLE> Coolant lines?? What coolant lines, haha lol. I didnt run them, I jsut allow the car enough cool down time. If you did want to you could use the coolant line that comes off of the bottom of the throttle body
madcrx69
Mar 16, 2009 07:48 AM
itsJDMyo
May 5, 2006 07:09 AM
chihuahuamanx
Apr 19, 2005 08:14 AM
sneakypete
Dec 22, 2003 06:55 PM
sneakypete
Sep 4, 2003 02:50 PM
