low hp on ls/vtec
Old Mar 14, 2009 | 08:26 PM
madcrx69's Avatar
Default low hp on ls/vtec
Hi, I have a boosted ls/vtec crx.
My normal whp on my car is around 425 whp on 23 psi.
It was a year since my last dyno and went to the dyno today and my surprise was on the same boost level I hit 340 whp.
It's the same motor, 190 compression on all 4 cilinders, tuning is good, but it's not doing more hp after 6500 rpm
The only change I made was to put a 2.75 inch piping infront of the turbo to the outside of the car. ( It's 2.5 feet long and comes outside the front left bumper).
Could it be possible that that piping is restricting the air coming into the turbo? I know the turbo sucks tremendous amount of air, but I don't know if this piping is blocking that. I just wanted some fresh air from the outside of the car. Any help would be appreciated. Thanks
Old Mar 14, 2009 | 09:00 PM
HighRevn's Avatar
Default Re: low hp on ls/vtec
Was it a different dyno? Plus what was the weather like last time you dynoed compared to this time? Theres alot of factors that could cause that.
Old Mar 15, 2009 | 05:43 AM
Rooftop voter's Avatar
Yeah, was it the same dyno? If so, that's a pretty huge gap, LOL!
Old Mar 15, 2009 | 09:37 AM
madcrx69's Avatar
Yes, it's the same dyno and it was kind of hot that day.
Old Mar 15, 2009 | 01:56 PM
AfTeRhOuRs209's Avatar
thats crazy, id like to know why that would happen.. id be furious.. bump
Old Mar 15, 2009 | 02:19 PM
TheThiefTheKnife'NTheGun's Avatar
did you check to make sure vtec was engaging
Old Mar 15, 2009 | 04:54 PM
madcrx69's Avatar
Yes, it's engaging!!
Old Mar 16, 2009 | 12:10 AM
cleve's Avatar
huh?
dyno time is expensive but what i would do is get rid of the pipe. try a run. see if that helps.
are you running lean at all? rich?
Old Mar 16, 2009 | 05:50 AM
madcrx69's Avatar
I already got rid of the piping and another thing i forgot is that on the previous valve cover I had two hoses to a catchcan for the engine to breathe better, but I bought a type r valve cover and I didn't want to make the two holes for the lines to the catch can. Maybe is that also a problem? The block is B18B and doesnt' have the stock pcv valve.
Old Mar 16, 2009 | 07:43 AM
turbociv910's Avatar
you def need some type of block ventilation.
Old Mar 16, 2009 | 07:45 AM
turbo boost's Avatar
check for boost leaks?
Old Mar 16, 2009 | 07:48 AM
brian...'s Avatar
Check the correction factor of both runs. My car makes 343 uncorrected, and 425 with corrected numbers for altitude and such.
Kid-jdm-teggy
Mar 21, 2015 06:45 PM
BigMike0147
Aug 17, 2011 05:52 PM
ed..
Aug 4, 2011 09:56 AM
blackhatchb20
18
Nov 8, 2004 05:47 PM
976
Feb 27, 2003 06:44 PM
