dyno result!good or bad?
QUOTE]i don't know what he's using but with his set up those are the kinds of numbers you would see using 440's, 12:1 fmu, afc, and race fuel. the compression is definitely causing him to have to run those boost levels in order to make those numbers. obviously, with a stand alone and higher compression you would make more power @ those boost levels.[/QUOTE]
is that possible tu run 20 psi whit an 12:1fmu (55+240psi=290psi )
seriously i dont use ems , hondata or whatever high pressure fuel system
tuning is all about fuel,air,timing
you wanna know more just pm me!
throu i know i can a do better whit my setup
ex:adding .2 compression=10whp+-,bigger turbo 60-1 compressor=15whp+-,more efficiency cooler=15whp=385+40=425whp @20psi est.
TurbotypeR made 440whp@23psi using a 60-1 compressor & 9:1 piston
so i guess im happy whit does number
ok say 1 car running 9:1 CR and another car is running 10:1 CR
say the one with 9:1 making 350whp , how much power will the one with 10:1 CR making ?
by how much more roughly ?
cuz after reading this post , im scared i will be getting low #'s with my 9:1 JE ........
static compression * (14.7psi + boostpsi)/14.7psi...
the cool thing is that if you look at the actual density of air in the cylinder, you always get a little more with boost, as opposed to compression. I hope that makes some sense...it's late
Nextelbuddy
Jun 3, 2004 08:58 PM
