ls turbo dyno results
298 hp @ 244ft/lbs of torque @11.9lbs of boost on 93 octan pump gas
my setup
sc61
rc 440 cc
aem fuel rail
8.3.1 compression wiseco pistons
eagle rods
stock block
stock head
my setup
sc61
rc 440 cc
aem fuel rail
eagle rods
stock block
stock head
Re: ls turbo dyno results (redturbocivic)
yeah why did u go so low with the compression? u can safely do 300-400whp with 9:1. nice number by the way at low psi.
i did it that low because i blew my motor up with stock internals, and i had those pistons lying around. i plan to got back next month and go for some 20 psi pulls
i ran low boost cause the motor only had 1000k on it so i want to hold backa bit next month im goin on the dyno again tring to pull 20 psi but ill see how much my injectors will do
Re: (turbokitssuck)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbokitssuck »</TD></TR><TR><TD CLASS="quote">wow, im going to have to call bullshit on this one. 300whp at 12psi with that ******* compression. you've got to be joking me!!!!!!
put that turbo on a stock setup(even though it doesnt have forged internals) and its not going to make 300whp so how you going to make 300whp with that low of compression.
Jesus christ, people need to call bullshit on posts like this.</TD></TR></TABLE>
easy there killer, you never know, i made 270 whp on a very small t3/t04b at only 10.5 on stock b18b. 300 whp on a sc61 at 12 psi isnt out of the question.
Re: (IntegraSTracer44)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraSTracer44 »</TD></TR><TR><TD CLASS="quote">I have a 95 integra gsr with 315hp at the crank and 255ft/lbs at 12 psi on 9 octane gas as of right now.</TD></TR></TABLE>
Where the hell does this fit in to this post? Anyway nice numbers! Turn up that boost to like 15 and blow that 300HP mark away!
JDM BR33D
10
08-09-2018 08:03 PM
2phast
08-29-2005 06:36 PM
BoostedGSRBubble
11-01-2003 02:24 PM
