dumping wastegate into downpipe vs not doing it
Old Oct 10, 2005 | 08:05 PM
Keith Pierson's bitch's Avatar
Default dumping wastegate into downpipe vs not doing it
The setup i have bolts the wastegate to the downpipe so that the dump goes back into the downpipe.. do you lose power from this? or is this still an efficent setup?
Old Oct 11, 2005 | 06:46 AM
drumking15's Avatar
18" from the dp off the turbo is fine to recirculate the dumptube gases back in...anything closer your gonna lose a lil bit of power....4-5hp...nothing major
Old Oct 11, 2005 | 08:10 PM
Default Re: dumping wastegate into downpipe vs not doing it (xxturbodreamsxx)
ok, cool, i bought the setup off of a drag crx from a local shop so i figured it would be fine, i jsut have never seen a setup like that... the flange is actually only like 4 inches away tho lol but 5 hsp isnt anything serious.
Old Oct 11, 2005 | 08:34 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: (drumking15)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drumking15 &raquo;</TD></TR><TR><TD CLASS="quote">18" from the dp off the turbo is fine to recirculate the dumptube gases back in...anything closer your gonna lose a lil bit of power....4-5hp...nothing major</TD></TR></TABLE>
i need to dig up a dno sheet... a guy was running an fmax kit where the wg dumps right into the exhaust 3-4" after the turbine outlet... he ran open dump and gained 40whp at the same boost level
Old Oct 11, 2005 | 08:53 PM
wow, well if it makes that much of a difference then damn, lol how exactly does that effect the power?? and does it matter if im running open downpipe also?
namewasdallas
Apr 7, 2010 08:27 AM
FastCougar
Welding / Fabrication
13
Sep 20, 2007 08:47 PM
HamiltonRex
Jan 12, 2006 07:46 AM
.RTErnie
May 4, 2005 04:41 AM
Yani
Oct 23, 2003 10:51 PM
