doing a d16z6 rebuild for boost
Old Jan 17, 2008 | 08:16 AM
notstreetlegal's Avatar
Default doing a d16z6 rebuild for boost
looking on fjdistributors.com first i would like to say im impressed. next i was looking at getting vitara pistons. i was thinking about running 10-15psi on engine. and i was wondering if i needed a block guard???
Old Jan 18, 2008 | 07:41 AM
1SiC 3DR's Avatar
Default Re: doing a d16z6 rebuild for boost (notstreetlegal)
plenty of people with turbo d's are pushing 20-30 psi on stock sleeves i personally think the only proper way to do a block guard is have welded in and the cylinder rehoned hope this helps you, there is a guy on here Autoworks is turbo dirty d freak plenty of useful threads on sohc turbo
Old Jan 18, 2008 | 08:22 AM
Joseph Davis's Avatar
Default Re: doing a d16z6 rebuild for boost (1SiC 3DR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1SiC 3DR &raquo;</TD></TR><TR><TD CLASS="quote">the only proper way to do a block guard is have welded in and the cylinder rehoned </TD></TR></TABLE>
Which accomplishes nothing. Show me a single stock sleeve that started cracking at the top as opposed to the middle of the bore. The cracks like to spread upward, but that's not where they originate.
My $0.02 is stock sleeve piston/rod engine = 400 whp. More than that you need a cam and some port work. Keep it simple.
Old Jan 18, 2008 | 09:05 AM
1SiC 3DR's Avatar
Default Re: doing a d16z6 rebuild for boost (Joseph Davis)
i will agree totally i am not a fan a block guards at all i was only making a statement if i had to do it that would be the way i would choose, but like i said stock d sleeve have seen serious numbers and boost pressures and keep it simple is def a wonderful statement the less bullshit the better
Old Jan 18, 2008 | 10:29 AM
Sorry to be an argumentative weenie on my end, I just hate that people drop time and effort on those things. You are correct, too, if they aren't installed correctly they will actually warp the bores from the install or from overheating.
Old Jan 18, 2008 | 10:34 AM
NonovUrbizniz's Avatar
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Joseph Davis &raquo;</TD></TR><TR><TD CLASS="quote">
My $0.02 is stock sleeve piston/rod engine = 400 whp. More than that you need a cam and some port work. Keep it simple.</TD></TR></TABLE>
stock rods and pistons??? or do you mean stock sleeves with aftermarket rods/pistons?
Anyone have experience with posting the cylinders? not much a negative effect on cooling and you can post it in the midway up the cylnder where side loading is the highest.
Or is it just not worth it?
Old Jan 18, 2008 | 10:59 AM
Default Re: doing a d16z6 rebuild for boost (NonovUrbizniz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NonovUrbizniz &raquo;</TD></TR><TR><TD CLASS="quote">stock rods and pistons??? or do you mean stock sleeves with aftermarket rods/pistons?</TD></TR></TABLE>
Yah, sorry if I lost people with my nomenclature. We call built stock sleeve engines piston/rod engines locally.
Old Jan 20, 2008 | 04:34 PM
1SiC 3DR's Avatar
there is plenty of people making 400hp+ on stock sleeves, turbod16.com is a great site for all turbo d questions and posting the block is kinda ur call, seriously the time and effort isnt worth it if ur really worries about the sleeves the just resleeve it, use the K I S S method it will save monies and time my friend
TurboDelSolEH6
Jan 18, 2008 08:41 PM
IA95civicDX
Mar 4, 2007 06:23 PM
07si
Feb 24, 2007 11:43 AM
civiceg500
Jan 11, 2005 05:32 PM
wm5holla
May 1, 2003 07:48 AM
