need help on gsr turbo
i need help on what to look for in a turbo for my ek i wanna run 12's maybe 11's on race gas at track i have:
gsr stock block with new rings and bearings
gsr head supertech spring retainers valves .5mm exhaust and 1mm intake 5 angle valve job bronze valve guides mild port type r cams with adj cam gears blox manifold blox 70mm throttle 440cc inj and 255 pump fly and 6 puck on 98 type r tran with quick shift kit p28 on crome with skunk2 susp and full race traction bars
get a 880's injectors or just stick with 550s I ran my dc2 stock block only have J/e piston and crower rods and stock head with type-r springs no port and polish gsr cams, made 440's hp and 320tq ran 11.6's with 1.60ft
Man U FTW
What are your power goals?? Seeing as this is a stock block and presumably on pump gas, 550cc injectors will be enough to meet your needs. They flow enough to support 370whp with a safe duty cycle. I dont think you'll be making more than that on pump gas with a stock GSR...
