Trying to do a rebuild
Old Feb 15, 2005 | 06:39 PM
94tegdude's Avatar
Default Trying to do a rebuild
im in the process of figuring out what to get for my 94teg RS rebuild. If i were to get 9.0:1 CR pistons 81.5mm bore what size sleeves would i need?
Old Feb 15, 2005 | 06:41 PM
SOHCD16y8's Avatar
just take your stock sleeves and get them bored .020 and honed, its like 180 to do i think at a good machine shop
Old Feb 15, 2005 | 06:52 PM
mr.beeks's Avatar
Default Re: (SOHCD16y8)
be carefull to machine shop that you bring it into
ask them if they make themselves responsible if after rebuild
you get piston slap...
im not kidding...
piston slap= when one of the sleeves is not bored straight and the piston
bangs against the sleeve while it travels its path.
Old Feb 15, 2005 | 06:53 PM
94tegdude's Avatar
Default Re: Trying to do a rebuild (94tegdude)
well im also planning on putting a turbo on so would i need new sleeves to run like 14psi or would stock ones be fine with bore and hone?
Old Feb 15, 2005 | 06:56 PM
mr.beeks's Avatar
14 pounds youll b OK dont be tempted to go higher
but just to be safe add some support to the sleeves in the outside..
Old Feb 15, 2005 | 06:59 PM
94tegdude's Avatar
Default Re: Trying to do a rebuild (mr.beeks)
thanx
Old Feb 15, 2005 | 10:33 PM
HmgLauj69's Avatar
if your going to resleeve it might as will bore that mug to at least 84mm
H22Luda720
Mar 20, 2006 01:33 PM
hondaapi
Apr 7, 2005 05:08 AM
B18 CYA
Apr 8, 2004 05:09 PM
Chuji
Sep 11, 2003 09:00 PM
1.8EG-T
May 16, 2002 12:42 AM
