Do i need a boost controller
Old Jan 13, 2005 | 12:15 PM
DXK Eg's Avatar
Default Do i need a boost controller
ok, i have a tial 38 mm wastegate and planing to run about 12 to 18 psi at the track. I have a apexi boost controller, planning to buy hondata s200, and i have never use a digital boost controller before are they any good ?? and the question is do i need it. If not i'm going to sell it to buy my hondata.
let me know if you need to know my setup..
Modified by dynasty-x-motorsport at 10:05 PM 1/13/2005
Old Jan 13, 2005 | 12:17 PM
adictionbass's Avatar
Default Re: Do i need a boost controller (dynasty-x-motorsport)
if you want to run two different boost leves, then you have to have some way to control it
Old Jan 13, 2005 | 12:36 PM
11psiTurboSI's Avatar
Default Re: Do i need a boost controller (adictionbass)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adictionbass &raquo;</TD></TR><TR><TD CLASS="quote">if you want to run two different boost leves, then you have to have some way to control it</TD></TR></TABLE>
^^^ What he said.
Old Jan 13, 2005 | 12:40 PM
DXK Eg's Avatar
Default Re: Do i need a boost controller (11psiTurboSI)
so this is just like an turbo xs dual boost controller.
Old Jan 13, 2005 | 12:44 PM
wantboost's Avatar
Who is Mr Robot?
what psi spring does your wastegate have?
Old Jan 13, 2005 | 12:50 PM
DXK Eg's Avatar
Default Re: Do i need a boost controller (wantboost)
i'm not sure i bought it new ..if that helps..
Old Jan 13, 2005 | 12:52 PM
wantboost's Avatar
Who is Mr Robot?
no, not really. email tial with the srial number on your wastegate (on the top) and ask them if they know what psi spring it was sold with
Old Jan 13, 2005 | 01:04 PM
DXK Eg's Avatar
i guess i will cal them. What about the apexi boost controller should i just dump that then.
Old Jan 13, 2005 | 01:51 PM
ill buy it off of you for $50
Old Jan 13, 2005 | 01:54 PM
DC2 BOOST's Avatar
If ur targetting 14-18 psi of boost u dont need the apex boost controller it depends what size spring is in ur wastegate try to keep the spring size at 14 psi all u need is a turbo XS manual boost controller is simplicity makes it easy to controll boost rather than the apex digital boost controller because its to complicated to use cuz i use to own one
Modified by DC2 BOOST at 3:04 PM 1/13/2005
Old Jan 13, 2005 | 01:59 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: Do i need a boost controller (DC2 BOOST)
^what?? The problem with going straight spring and mbc is that it doesnt allow for the holding capabilitites that ebc has, like holding the valve completely closed until the desired psi is reached. EBC's offer a more extreme boost ramp and overshoot and stabilization control
Old Jan 13, 2005 | 02:01 PM
DC2 BOOST's Avatar
it holds fine wid mine
93turbo16's Avatar
I agree but electronic boost controllers can be a pain in the but, you get more spiking and things like that with a MBC.
Old Jan 13, 2005 | 02:02 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: (93turbo16)
yea, ebc's are a bitch to setup, but when done properly, they're so much fun
Old Jan 13, 2005 | 02:03 PM
wantboost's Avatar
Who is Mr Robot?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2 BOOST &raquo;</TD></TR><TR><TD CLASS="quote">it holds fine wid mine</TD></TR></TABLE>
it's not a matter of it holding boost, its a matter of how quickly peak boost is acheived, an ebc will always make peak boost quicker than an mbc
Old Jan 13, 2005 | 02:04 PM
93turbo16's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">yea, ebc's are a bitch to setup, but when done properly, they're so much fun </TD></TR></TABLE>
To bad mine didn't work out.
Old Jan 13, 2005 | 02:05 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: Do i need a boost controller (93turbo16)
well, it was the first evc hks ever made, so it was really really really old. that andyou got it for 70 bucks
Old Jan 13, 2005 | 02:07 PM
93turbo16's Avatar
I was just asking for trouble. But it EBC are nice because they are mounted right in the car and you can play with them. But don't get to boost happy now. Electronics just don't like my dad. I am going to try it in the civic soon enough. Damn 16G wastegate.
Old Jan 13, 2005 | 02:19 PM
DXK Eg's Avatar
thanks for the info..
hold your breath
Mar 6, 2007 07:47 PM
Spec R_GSR
Jan 22, 2007 12:20 PM
brixity
Apr 5, 2005 05:59 PM
vtec.dc2
Dec 28, 2002 08:03 AM
simike
May 10, 2002 03:01 PM
