Using wastegate with boost controller.
Old Dec 27, 2002 | 09:06 PM
vtec.dc2's Avatar
Default Using wastegate with boost controller.
If i'm to have a tial wastegate and don't want to run any higher than what the spring rating is, do I need a boost controller in that case?
Lets say its .45bar spring, will boost controller have more control so it don't go over .45bar?
Thanks
Old Dec 27, 2002 | 09:28 PM
DeepSi's Avatar
Default Re: Using wastegate with boost controller. (vtec.dc2)
if you want to run at the rating of the spring in the wastegate, then you dont need a BC.
Old Dec 27, 2002 | 09:29 PM
ffgeon's Avatar
if you dont want to go over .45 just leave the top fitting open to atmosphere. dont put in the boost controller if your not gonna use it.
Old Dec 27, 2002 | 09:41 PM
ninesecrx's Avatar
Default Re: Using wastegate with boost controller. (ffgeon)
You do want to use a boost controller even if you just want to boost what the spring rate is. Heres why; Running a wastegate without the boost contoler will let the wastegate start opening up earlier then what the spring rate is. With a boost contoller on there, it will keep the wastegate completly closed until the desired boost and let it open at once.
Old Dec 27, 2002 | 10:11 PM
ffgeon's Avatar
Default Re: Using wastegate with boost controller. (ninesecrx)
sorry mike, my bad, i fooked up
Old Dec 28, 2002 | 08:03 AM
vtec.dc2's Avatar
i thought i could get away without one, but that sounds like a good reason to have one..
thanks for all replies
ek9vboi2
Jul 18, 2004 08:14 PM
Racer X
Mar 27, 2003 01:07 PM
shingles
Jan 24, 2003 01:58 AM
The Punisher
Jun 21, 2002 09:57 AM
DIRep972
Aug 18, 2001 03:34 AM
