diesel turbo?
Old May 3, 2010 | 12:12 PM
rustanghunter's Avatar
Default diesel turbo?
ok this is a dumbass question, but i work around heavy equipment everyday, a coworker offered me the turbo from his diesel tractor the housing is about the same size as my brothers garret t3 can a turbo from a deisel engine work in a high revving gas engine? i seem to recal a f20(?) powered ef in super street last year that had a tractor supply turbo, what would need to be changed?
Old May 3, 2010 | 01:16 PM
ScorpionT's Avatar
Default Re: diesel turbo?
Diesel turbos can be used, but the biggest thing you need to find out is what turbine wheel/compressor combination is used.
Old May 3, 2010 | 01:19 PM
accord_raffi's Avatar
It can be used as long as you can spin the thing...some are very big turbos.
Old May 3, 2010 | 04:18 PM
thehatchninja's Avatar
Search holset turbos + honda.
Old May 3, 2010 | 06:34 PM
Bseriescivic5's Avatar
I run an RHC7 found on hitatchi heavy equipment vehicle and its been working out pretty good for me ~300whp 8psi, built gsr. T4 divided footprint, has 56mmcompressor, 62mm turbine (inducers). Wants a lot more boost though 5100ish full boost maybe a bit sooner (cx dash= no tach). I say if you got it free/dirt cheap.... run it
civic2slo
Apr 2, 2014 07:31 PM
damndan23
Mar 20, 2009 05:38 PM
LOwrestling2001
Nov 27, 2002 09:59 AM
VtecInteg95
Aug 24, 2002 08:06 PM
00b18b
Nov 25, 2001 11:08 AM
