arp head studs without washers on accident
Old May 3, 2010 | 12:55 PM
2wheelhunter's Avatar
Default arp head studs without washers on accident
I came to inspect an engine built by a friend and found that the washers for the ARP head studs were not installed. We still have the washers just not sure what route to take. We dont want to spend the money on a new headgasket if it is not needed. My question is, can we install the washers by doing one at a time thus not releasing pressure on the headgasket..? will this work?
Old May 3, 2010 | 01:55 PM
siblues's Avatar
Default Re: arp head studs without washers on accident
It probably can be done that way but the manual states that releasing the pressure that way can cause the head to warp it states to release the head by loosening the nuts in a specisfic order and by only turning them 1/3 of a turn at a time until you have them all off.
Old May 3, 2010 | 02:39 PM
thanks i guess.. thats what we did.. seems like it will be fine i guess time will tell
Old May 3, 2010 | 02:57 PM
th3pwn3r's Avatar
Make sure to measure them up for stretching and such.
Old May 3, 2010 | 03:21 PM
mrbigg9032's Avatar
A head gasket is like $30 I think...
Old May 3, 2010 | 03:28 PM
RickyLee53's Avatar
Thats if your undoing all the bolts, he's just planning to remove 1 at a time to put the washers on.
Old May 3, 2010 | 04:11 PM
nsxter's Avatar
so you would rather take a chance at ****ing up a built motor then spend some money to on a new head gasket to fix it right how dumb are people
Old May 3, 2010 | 05:18 PM
per4mance's Avatar
Try around 60 or so unless you use crappy autozone ones
Old May 3, 2010 | 05:22 PM
...esteban's Avatar
Princess
Just replace the gasket and do it the right way.
Old May 3, 2010 | 05:30 PM
Sordz's Avatar
if the engine hasnt been ran(heat cycle) you could even remove the head and the head gasket is fine to use again. The real question should be if you should even use the washers at this point.
Old May 3, 2010 | 06:26 PM
EARLdaSQUIRREL's Avatar
official honda whore
do one at a time and you wont have a problem... people should really pay attention or maybe have experienced builders do their motors for them
Old May 3, 2010 | 07:05 PM
vwbased's Avatar
have a nice day
Old May 3, 2010 | 07:11 PM
vwbased's Avatar
have a nice day
DelSol-B18
Sep 8, 2012 06:24 PM
( o )( o )
Jun 2, 2012 04:13 AM
EJ1 wilcox
Feb 23, 2006 03:08 PM
busychild
Sep 30, 2004 06:12 PM
RTW DC2R
Sep 9, 2002 01:58 PM
