turbo too big?
Old Nov 23, 2001 | 07:53 PM
00b18b's Avatar
Default turbo too big?
i have a garrett turbo with a comp A/R .60 turbine A/R.63. is that too big for an auto teg LS? will i get a lot of lag? or should i just use the tdo5h instead?
Old Nov 23, 2001 | 07:55 PM
MiraiZ's Avatar
Default Re: turbo too big? (autoLS)
lag! a lot of needs to be done to spool it.....is it a bb??
Old Nov 23, 2001 | 08:05 PM
00b18b's Avatar
Default Re: turbo too big? (MiraiZ)
not bb i got it off a n old t-bird
Old Nov 23, 2001 | 08:08 PM
MiraiZ's Avatar
hold the phone...is that a t-3? I heard that T-Birds had small turbos but don't know the model...if its a t-3, you should be ok
Old Nov 23, 2001 | 08:14 PM
00b18b's Avatar
yep its a Garrett T3 comp A/R .60 turbine A/R.63 stamped on it. so this is a small turbo you say?
Old Nov 23, 2001 | 09:07 PM
Rob03Pro5's Avatar
That turbo will be nice on your motor. TurboInteg95 has that turbo too.. they spool quick and can give nice hp at higher boost levels. The .63 is a good choice for that size turbo on your motor.
Old Nov 24, 2001 | 01:14 AM
MiraiZ's Avatar
Sorry, I misread your original post...I thought you said t-60, which is way too big...t-3's are good ...you'll spool quickly, and it has a lot of potential!
Old Nov 24, 2001 | 07:58 AM
bigTom's Avatar
its not big
Old Nov 24, 2001 | 08:46 PM
csufweed's Avatar
nope, eclipse's use T25 turbo's which spool very quickly! A T3 will only have a little more lag that a T25, which isnt much at all. However, a ball bearing would be awesome in comparison, but cost may be substantially higher.
Bottom Line... enjoy the T3! It should be pretty sweet!
Old Nov 24, 2001 | 09:16 PM
TurboInteg95's Avatar
Auto LS, that turbo is actually very well suited for stock LS motors. They spool up fairly quick and the compressor is fairly suited for that motor. Your powerband will be very broad as opposed to the peaks that most Honda motor produce, it makes for a good street turbo and it can hold it's own at the track.
Old Nov 25, 2001 | 11:08 AM
00b18b's Avatar
Default Re: turbo too big? (TurboInteg95)
hey turboInteg95 i hear u have the same turbo as mine? have u dynoed it yet? what's your setup? thx
hondahatch741
May 30, 2005 12:36 PM
DC2 BoZz
Sep 25, 2004 07:44 PM
turbohf
Mar 14, 2003 08:28 AM
metal-x
Nov 26, 2002 01:01 PM
M.A.R.C.
Jun 10, 2002 03:23 PM
