Darton repair Sleeves
I got a b18c5 with 81.5 mm forged piston i push 10psi @ 327whp i want to up the boost around 16 to get around 450whp for my second boost option (dual boost controller) sorry for my english
i have see for 650$ vs 1200$ MID sleeves
Darton Sleeves Repair (Guarteed 20psi) and stay open deck and darton use another metal material suposed to be moore hard to broke
10mm moore big then stock sleeve do you think its a good alternative for the WHP i want
Re: Darton repair Sleeves (Dark19Acura)
Ran 19psi stock sleeves. Would boost more but no traction. No reason to sleeve. 81.5mm got a block guard but you really don't need it.
ok soo i will try the next summer my second boost it will be around 427whp 1 stage at 327whp and the second i hope it will be overkill if i use this one if i broke i will change for someting like repair sleeve or MID sleeve
soo all question its because i need to do a ring job sooo i see all in my rearview i can wait again
Man U FTW
If you're looking for 450whp, stick with the stock sleeves. Aftermarket sleeves would give you peace of mind that nothing is going to happen, but they aren't necessary by any means. I'm actually looking to make right around 450whp myself and i'm on stock sleeves with a higher static compression (9.8:1)
