D16 ignition break up@5,500
Old 10-10-2010, 09:49 PM
nihad's Avatar
Default D16 ignition break up@5,500
what should i do.. I have installed new BKR7E gapped below .030 and also new cap but nothing still doing it... Was gonna race my hatch at CFR but this prevented me from doing so.. Help me out... Thanks..
Old 10-10-2010, 09:57 PM
Moderator
TheShodan's Avatar
Default Re: D16 ignition break up@5,500
hows your internal coil in the distributor? The ignitor?
Old 10-10-2010, 10:35 PM
LightningTeg's Avatar
So many variables here. How much timing? How much boost? Turbo setup? Fuel? Power?
Old 10-11-2010, 02:22 PM
nihad's Avatar
E85 its the car in my sign tuned by MAP worked great till now i had some issues with my ignition set up earlier got the ignition code and then i figued the coil is bad so i opend it up and cleaned the cap and rotor and it worked great now i am not getting a code for igintion system but its breaking up.. I purchased a new cap and some brk7e at .028 and nothing same ****.. I kind of want to swap dizzys with some one..
Old 10-11-2010, 02:27 PM
newtype_33's Avatar
i had the same problem and it was my ignition coil.
Old 10-11-2010, 02:30 PM
nihad's Avatar
well ill fix my code 17 first to see if that is the problem..
Old 10-12-2010, 10:02 PM
b20ricepower's Avatar
Try a gap around .022 if you are getting close to .030 it might be too much for the stock coil.Some people go even smaller gap than that. If that doesnt work you might as well upgrade to an external coil. yea def take care of the mil first
Old 10-13-2010, 01:06 PM
nihad's Avatar
Ok, after talking to my tuner i and he figured out it was the speedo not working causing my setup to break up as it did.. and so i fixed the speedo cable yesterday and drove it worked great car felt another 100whp faster.. Speedo cable broke in half so i welded it up and ground it down to fit back in and it broke again last night so ill just get another one out of my crx dx. Nothing to do with the dizzy at all.. I will gap my plugs down to like .023 or so.. and what do you guys think i know there is alot of smart engine builders/tuners here what do you guys think if i was to use a MSD external cap and coil.. and maybe some thicker plus then what i have now are 8mm advance auto parts red wires.. Which set up should i do.. Thanks and would i gain any power..
Old 10-13-2010, 01:07 PM
nihad's Avatar
also which coil should i use the accel or the msd round style or the flat box ones from chevy or ford.. thats the 4 diff options my advance auto parts carries..
Old 10-13-2010, 01:11 PM
Garage 808 Hatch's Avatar
sounds to me like your ignitor may be getting too hot, and freaking out. I had similar issues on my drag car. Fine on the dyno, but at the track, under the hood gets hotter, and the track is a bit more load than our dynojet produces, caused break up issues. replaced the ignitor, and it went away. now i just ice my distributor between rounds, and have 0 issues. if i dont ice it, i have break up, even at .020 gap
Old 10-13-2010, 01:20 PM
nihad's Avatar
ill remove my hood when i run at the track and i shouldnt have any issues..
Old 10-13-2010, 09:47 PM
you still may, but it might help
Old 10-14-2010, 02:28 PM
nihad's Avatar
What do you guys think and what do you run.. I dont want some extremly expensive aem system at this moment just would like to find out the cheapest upgrade... Ill remove the internal coil but for the moment its still works great.. I have buddy of mine and he said when his z6 was just engine NA he felt it gain some power and ran a 14.5 1/4 mile. Lightweight crx.. hf i think.
Old 10-14-2010, 02:35 PM
2k.civic.si's Avatar
Switch to msd sci with blaster coil...then there is a trick you can do to completely remove the ignitor...im going to be selling the kit soon once i have it perfect
Old 10-14-2010, 02:42 PM
nihad's Avatar
I want to keep the coil pack msd.. I dont want pencil coils at the moment.. Id just like the external coil and cap.. What style should i get coil wise.. or are they all the same.. I dont want to ge the aem setup i bet its pricey..
Old 10-14-2010, 02:55 PM
go to msd ignition and msd coil....still uses the cap and rotor....i just have a way to completely remove the ignitor.
mightyjoecivic
11
07-13-2022 08:04 PM
kelvinchau25
08-29-2006 07:05 PM
93solcontender
03-09-2003 02:33 AM
kungfuSiR
05-18-2002 04:24 PM
GTEater
06-24-2001 02:58 PM
Quick Reply: D16 ignition break up@5,500
