B16 Build 400+ goal. Let's see if i can get it.
Old 06-23-2010, 09:37 AM
Silvertc's Avatar
Default B16 Build 400+ goal. Let's see if i can get it.
Hey Guys, just sharing my build. I got the motor through a trade, but needed to be rebuilt because last guy chipped the piston and put a chip in cylinder #2. I decided i've never messed with boost, so i rebuilt it. I got the complete motor from the kid, and refreshed everything. Nothing to crazy, just simple boost build..
(MOTOR)
B16 Dart Sleeves (82.5mm after bore to fix)
Scat rods w/ARP rod bolts
CP Pistons 9:1
Clevite Bearings
Cometic head gasket
ARP headstuds
B16 head with Full Supertech valve train
Edelbrock Victor X intake manifold
Skunk2 65mm TB
Stock B16 crank, micro polished, checked.
Stock GSR cams
Moroso Oil pan
New Valve seals
New OEM oil pump and pick up
All new OEM gaskets
-BES Racing Shop Balanced, clearances checked, (rotating assembly)
I assembled the rest.
(Trans)
GSR with brand new Mfactory Helical LSD
stock flywheel
Competition Stage 4 Clutch
(Turbo)
AFI Ramhorn
Tial Waste gate
Tial 50mm BOV
Garret T3/T04E 57trim
Custom Downpipe and intercooler piping
CX racing 31x11.5x3 Intercooler
(Fuel)
93 Octane
255 Walbro
Inline Fuel filter
Aeromotive A1000 FPR
Precision 1000cc injectors
BDL fuel rail
Goals Shooting for 400-500HP, Guy that had motor before me with some junk parts made 423hp. Some junk mini ramhorn, intake manifold just to name some. I know I'm probably missing few things, ill update as i go.
Old 06-23-2010, 08:08 PM
boostedb16a3's Avatar
Default Re: B16 Build 400+ goal. Let's see if i can get it.
That's a pretty stout setup buddy. I would go SC61 at bare minimum. I'm building a b16a2. without sleeves and less head work but with a sc6262. I'm looking to make 475whp.
Old 06-23-2010, 08:36 PM
boostedeg302's Avatar
That turbo will reach 400 but i would agree on going a bit larger to reach 500whp just so the turbo isnt maxed out. Especially if you want a little wiggle room for more power. Motor looks gorgeous tho and I really like the blue. Great job
Old 06-24-2010, 05:45 AM
Silvertc's Avatar
Thanks guys for the comments and advice. Ya, I most likely won't reach 500 without maxing it out. Ill use it for this season and probably upgrade during this winter. I spent a lot of time trying to clean everything up, freshening, and new hardware.
Old 07-08-2010, 11:26 PM
Silvertc's Avatar
Well here are updates. Got the car running on just base map. Should be dyno tuning saturday..
AFI Ramhorn Manifold
Old 07-09-2010, 03:31 AM
joe111599's Avatar
Right on! Keep us posted! Very cleeeeen setup!
Old 07-09-2010, 11:30 AM
AlexDphoto's Avatar
clean setup sir! i like
Old 07-09-2010, 11:47 AM
spoolin99si's Avatar
Nice and clean. Post up the numbers when you get them.
Old 07-11-2010, 06:02 PM
Silvertc's Avatar
hell of a dyno day. Had problem after problem. it just wasn't my day. Wastegate was acting up, then spark issues. made 420 on 22lbs. need to fix fuel issue tho. ill keep you guys updated...
Old 07-29-2010, 01:41 PM
Silvertc's Avatar
Video will be posted soon.
Old 07-29-2010, 01:54 PM
neverstop's Avatar
NICE setup man! I can't imagine driving a 400+whp b16....need more pics of the car and setup!
Old 07-29-2010, 04:27 PM
turbociv910's Avatar
what happened right after 7500rpm???
Old 10-11-2010, 10:38 AM
slostjoe's Avatar
X2
Old 10-12-2010, 12:05 AM
NLR808's Avatar
i love how clean the setup and car is, 60-1 turbo would be nice or a little bigger
Old 10-12-2010, 05:37 PM
FrankenBlock's Avatar
thats pretty sick man, have you thought about swapping the gsr cams for something else? i went through several cams before i found a set that worked...Brian Crower felt the best so far, i think they would fit pretty well in with your build.
Old 10-12-2010, 07:53 PM
hediki12's Avatar
Originally Posted by slostjoe
X2
looks like he ran into some knock...
to the op very nice build!
Old 10-13-2010, 04:12 PM
rez624's Avatar
this is great. im planning on building a b16 myself and this has actually been a huge help. keep updating! thanks man!
Old 10-14-2010, 03:28 PM
mm9023's Avatar
A++ looks nice
Old 10-14-2010, 03:32 PM
JDM-EK-B18C5's Avatar
Nice b16 yo
84Riceeater
Northwest (Sales)
17
07-10-2011 08:00 AM
Silvertc
08-19-2010 07:27 PM
Samuels
09-21-2006 04:25 PM
the.hamburglar
01-31-2006 07:33 AM
Quick Reply: B16 Build 400+ goal. Let's see if i can get it.
