Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Overheating issues
Old Jul 27, 2008 | 12:32 PM
crx-si's Avatar
Default Overheating issues
I run a 91 Integra on an oval dirt track and am having alot of trouble with it overheating and there area couple of other guys that have the same trouble.???
Old Jul 27, 2008 | 02:50 PM
bosco500's Avatar
Default Re: Overheating issues (crx-si)
Have you tried an oversized radiator and water wetter?
Old Jul 27, 2008 | 02:52 PM
JW racing's Avatar
Have you upgraded your OEM radiator to a larger unit? Also what kind of screen have you got in front for protection of rocks and dirt buildup?
Old Jul 27, 2008 | 03:43 PM
boostedh23's Avatar
you could pull out the thermostat & put in a restrictor plate, oversized rad & water wetter as previuosly suggested and higher pressure rad cap
Old Jul 27, 2008 | 04:55 PM
Slow*Jim's Avatar
you could cut a big hole in the hood
Old Jul 27, 2008 | 05:06 PM
chad's Avatar
Moderator
Default Re: Overheating issues (boostedh23)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedh23 &raquo;</TD></TR><TR><TD CLASS="quote">you could pull out the thermostat & put in a restrictor plate, </TD></TR></TABLE>
NO DON"T DO THAT!! wrong information!!!
so how big of hole does he need&gt;? you do realize that is all a thermostat is, is a restrictor plate??/
Old Jul 27, 2008 | 05:30 PM
crx-si's Avatar
I havent tried watter wetter diden't think it worked from what i have heard i am thinkin about getting a rad from a 94 integra with AC its a double core. Any other similar rad that will work? I have also cut the center out of the themostat same issue fan hooked up to run constant, i have expanded metal in front to keep dirt and rocks from hittin the rad.
Old Jul 27, 2008 | 07:33 PM
Crx Jimmy's Avatar
Default Re: (crx-si)
all 91 integras had dual core rads, ifs its a sotck 91 rad from 1991 it might be time to replace. it might have deposits built up inside, you gan get aluminum ones off ebay for under $200
Old Jul 27, 2008 | 07:47 PM
JuanTushag's Avatar
I have had problems with several race cars overheating. My cure has been to fabricate ducting that guides the air into the radiator, and does not let it travel around and above the radiator.
I cannot stress how effective of a cure this was. So much of the air entering the front of the car is allowed to flow around the radiator in stock form that it not only by-passes the radiator,,, it also creates high pressure behind the radiator,,therby reducing flow even more. Even when I went to a large aftermarket radiator, the cooling gaines were modest when compaired to proper ducting.
An additional gain is downforce created since you are limiting the amount of air flooding the engine bay. The air that enters is used much more efficiently.
I did this mod on my CRX, and just completed it on my H2 civic ( 2 months ago ). I ran the car at Buttonwillow in near 107 degree weather. The car never ran over 190 degrees .
I will try to post some pics of the civic set up. On the CRX it was just some carefully made aluminum ducting. For the civic I made a mold and pulled a fiberglass part off of it.
JT
Old Jul 27, 2008 | 09:26 PM
Weel's Avatar
Default Re: (JuanTushag)
in for the pics, looking at doing this to my civic
Old Jul 28, 2008 | 01:55 AM
crx-si's Avatar
I don't think 91's all had dual cores i have only seen singles i have scrapped 5 or 6 of em and none had a dual and pars stores only list singles.
Old Jul 28, 2008 | 06:20 PM
crx-si's Avatar
Anyone ever use the ford tarus sho fan it is said to push around 5000 cfm
Old Jul 28, 2008 | 06:29 PM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx-si &raquo;</TD></TR><TR><TD CLASS="quote">Anyone ever use the ford tarus sho fan it is said to push around 5000 cfm</TD></TR></TABLE>
If you're moving faster than 50 MPH, I don't think a different fan will help much.
Have you tried a new T-stat?
Have you done a leakdown test (i.e. headgasket)?
There's a number of bigger radiators out there, look on Ebay.
-Chris
Old Jul 29, 2008 | 01:52 AM
crx-si's Avatar
Default Re: (Chris F)
Was useing a fully rebuilt engine untill that went and are now useing an engine from a donor car and having the same troubles so i doubt its anything to do with the thermostat or the head gasket.
Old Jul 29, 2008 | 05:50 AM
Another Drew's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JuanTushag &raquo;</TD></TR><TR><TD CLASS="quote"> My cure has been to fabricate ducting that guides the air into the radiator, and does not let it travel around and above the radiator.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F &raquo;</TD></TR><TR><TD CLASS="quote">
-Chris</TD></TR></TABLE>
Old Jul 29, 2008 | 05:51 PM
crx-si's Avatar
I think i am goin with dual fans up front and fabbing up a cowl hood with a sho fan mounted in it to pull the heat out from the engine bay, as well as a double core rad along with channeling all air into the rad.
Think this will work.
Old Jul 29, 2008 | 06:01 PM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx-si &raquo;</TD></TR><TR><TD CLASS="quote">I think i am goin with dual fans up front and fabbing up a cowl hood with a sho fan mounted in it to pull the heat out from the engine bay, as well as a double core rad along with channeling all air into the rad.
Think this will work. </TD></TR></TABLE>
It really ought to work. Most B-series motors just aren't overheating on higher speed tracks (higher speed than a dirt track) so some more air should help!
What gear are you using on the oval, 3rd? I have no idea how fast these are.
[edit, damn, you're in Canada and overheating? You're doing something wrong. Maybe Canadian Integras got half-rads or something?]
Old Jul 29, 2008 | 06:29 PM
crx-si's Avatar
Well we are running in about 90 degrees in second gear constantly between 5 and 7 thousand rpm's rarely 3rd for up to 15 minutes. And yes we have the full rads to LOL
Old Jul 29, 2008 | 06:39 PM
Chris F's Avatar
Ah ha. That'll do it. Try driving twice as fast
Old Jul 30, 2008 | 01:58 AM
crx-si's Avatar
And the front is constantly pulgging up with mud.
Old Jul 30, 2008 | 11:21 AM
JuanTushag's Avatar
sorry i have not posted pics of my ducting yet. i am on the road and will be back in town sat night
Old Jul 30, 2008 | 11:26 AM
EdoMoto's Avatar
Im running a fill sized radiator Fluidyne. But i dont have any ducting around the radiator. And i run no fans the water is always cool. But if i draft someone for 1 lap it goes up.
Edo
Old Jul 30, 2008 | 12:31 PM
JuanTushag's Avatar
Default Re: Overheating issues (EdoMoto)
how would you know , your never behind anyone!!!
Old Jul 30, 2008 | 12:58 PM
EdoMoto's Avatar
Default Re: Overheating issues (JuanTushag)
Lapping traffic. U know what i mean.
Edo
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JuanTushag &raquo;</TD></TR><TR><TD CLASS="quote">how would you know , your never behind anyone!!! </TD></TR></TABLE>
Old Aug 3, 2008 | 05:27 PM
crx-si's Avatar
Raced today with the new settup no dual core rad tho, cowl hood with the fan pulling the air from the engine bay as well as two fans pulling air in through the front of the car worked great won all three races.
jaydim
Jul 3, 2008 07:20 AM
Eibach95Civic
Aug 17, 2006 05:03 PM
budget
May 26, 2005 10:08 AM
Origin
Oct 12, 2004 11:30 AM
SupaFly_Honda
Oct 21, 2003 08:33 AM
