Compressor surge...
Old Jul 21, 2008 | 02:32 PM
Hmotoredcoupe's Avatar
Default Compressor surge...
D15B7 on 7psi, from 0-3 or so psi it flutters when i let off, but 6 or 7 psi the bov blows off then still flutters. Brand new Turbo XS BOV and new vacuum lines. Any ideas?
Old Jul 21, 2008 | 02:36 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Compressor surge... (Hmotoredcoupe)
any washers in there? if so loosen it up. i dont think you are gonna get anything other than surge that low.(0-3psi)
Old Jul 21, 2008 | 04:35 PM
No washers in it. Spring be too hard maybe? And why would it surge after blowing off, spring too hard to keep open and dump everything out?
Old Jul 21, 2008 | 04:37 PM
SlowB16si's Avatar
turbo xs RFL bov? Weird that bov usually is annoyingly loud even if you hit half a pound or boost.
Old Jul 21, 2008 | 04:43 PM
No not the rfl, its just a little one, i think its the type s.
Old Jul 22, 2008 | 03:08 AM
Mr. Badwrench
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hmotoredcoupe &raquo;</TD></TR><TR><TD CLASS="quote">No washers in it. Spring be too hard maybe? And why would it surge after blowing off, spring too hard to keep open and dump everything out?</TD></TR></TABLE>
you actually need pressure to open it. if the pressure out of the piping isnt enough to overcome the spring pressure, you will get a little surge.
if it is only that low, i wouldnt worry. i have the biggest spring in my tial, just to make sure it stays shut, mine surges at low boost too.
Old Jul 22, 2008 | 06:01 AM
I dont get why its doing it after it blows off too though?
Old Jul 22, 2008 | 06:46 AM
Mr. Badwrench
when it blows off there is good pressure, as it blows off, there goes the pressure, out the valve. until there isnt enough to keep the valve open. if it is doing it at that low of boost only, dont worry about it.
ITRICED
Mar 4, 2009 09:33 PM
t57b18
Apr 5, 2007 06:19 AM
dustin
May 9, 2005 12:12 PM
sporkcrx
Mar 11, 2005 04:34 AM
knightnam
Jul 5, 2004 09:41 AM
