Tial blow Off valve
Re: Tial blow Off valve
n00b 1 "So Eric, what spring do you have on that BOV ?
n00b 2 "12 pound spring"
n00b 1 "and you boost to 20 psi right ?"
n00b 2 "right."
n00b 1 "When does the surge occur ?"
n00b 2 "at 5, 10, and 11 pounds "
to top it off, the end Title states "TiaL 50mm BOV, da Surge maker."
They make it seem as if that's what's supposed to happen and it's normal. It's NOT. Compressor surge will destroy that turbo very fast. Ofcourse you'll have surge when you're below the boost level of the BOV spring. n00bs.
OP, since you're having this problem at a high RPM range then I'de recommend finding out what spring you have in that BOV and get a weaker spring put in.
n00b 2 "right."
HT White Ops
n00b 2 "right."
n00b 2 "right."
What are you talking about? Do you have any idea what that video is about? Its Synapse doing his best to degrade Tial's BOV to better himself and the Synchronic BOV. Pay attention son.. Nowhere in that video do they say Comp Surge is good and normal. The are implying the exact opposite.
That synapse video is all BS, they put the wrong spring in there to make it perform poorly, here is the proof:
http://www.youtube.com/watch?v=8-JTfgpFKrM
Yep that first posted video above is one of the many Synapse attempted hit job video on Tial.
I guess when you cant beat someone else product, you falsify a test and make a youtube video of it cause people believe everything they see on the internet without doing any research to understand the background.
To the OP: What spring do you have in the BOV and what in/hg of vac you pulling at idle? Seems most commonly people dont understand how to select the proper spring, many think that you select the spring based on how much boost pressure you run... which is incorrect.
Any chance you can get a short clip of the flutter your talking about for us to see. It would make it easier to judge if it is compressor surge and something to be concerned with.
please give more details on the setup including engine, whp, how you have vacuum routed to the BOV, what rpm are you getting the fluttering? what spring do you have in the BOV?
in my experience i get some fluttering at low rpm/ low boost. blows off clean at higher boost and rpm. and by fluttering i do not mean surge, i dont think ive ever heard a turbo surge in person much less my own car.
lol hey I never said I knew for sure I just googled Tial to see what it sounded like and noticed it made the sound that this guy is talking about. So i let him have a look to see for himself
Ok im sorry i didnt give more info Here it is
b18c port and polish head
stock bottom end
valves springs retainers buddy club
buddy club spec 3 cams with cam gears
-AFI 304ss Tubular Ramhorn Manifold, Limited Lifetime Warrany
-AFI 3" Stainless Downpipe w/ braided flex and O2 bung
-AFI Stainless DIY dumptube kit
-AFI 26x6.5.3.5 Garrett Core Backdoor Front mount Intercooler
-AFI 2.5'" Powder Coated Charge Piping Kit, Bead Rolled
-AFI Street oil line kit (AN fittings, Braided line)
-Garrett T3/T04e 57 trim
-Tial 38mm MVS V-Band Wastegate
-Tial 50mm Q Blow-Off Valve
with a s300 hondata
I hope thats enough info oh i and 5 lbs of boost
stock bottom end
with a s300 hondata
i was told that the spring inside the BOV has to be the same vac pressure your getting at idle. am i right? like if my car is 21 vac at idle i need a pink tial bov spring so it can work properly.
well i dont know about the vac yet ill try to find out some more info on that. Now some one asked about my cams well they seem to wanna rev up to 9k but i just leave it at 8200rpm so yea. The car is not fully tuned yet only because i dont have a boost controller. well maybe if i use my spring like it should be used i wouldnt have the problem hopefully
i think most honda applications can use the 11psi spring with no issues. the 12lb may be a little too heavy (refer to that first video of the subby)
See link to chart for spring selection in the post before this one... you need to know how much vac (in/hg) your motor pulls before you can properly select a spring as I indicated in my first reply.
Just saying generally this one will work cause it work on someone elses is not the way to pick a spring... especially with those cams which probably greatly affect how much vac (in/hg) your motor pulls at idle.
also i just read the part where he is only running 5psi. thats why its fluttering. completely normal. but you should still check to make sure you have the right spring. might need a lighter spring with those cams but follow the instructions above to be sure
