Cometic HG Help
Old Dec 14, 2004 | 11:39 AM
MooreBoost's Avatar
Default Cometic HG Help
I was about to order a Cometic HG for my Z6 but when I went to select the bore the smallest they offered was .5mm larger than the stock bore. The tech said that wouldnt matter, but I just wanted to double check. Can I run a 75.5mm HG on a 75mm block?
Old Dec 14, 2004 | 01:03 PM
MooreBoost's Avatar
Default Re: Cometic HG Help (tegunderpressure)
Old Dec 14, 2004 | 05:45 PM
earl's Avatar
No problem at all with using a 75.5mm with your 75mm bore. Plenty of meat in that area.
Now if it was a 75mm gasket on a 75.5mm bore, that could be a problem.
Old Dec 14, 2004 | 05:53 PM
MooreBoost's Avatar
Default Re: Cometic HG Help (earl)
Awesome, thank you!
f1 vtec
Jul 15, 2020 02:47 PM
turbotime
Oct 12, 2005 08:04 AM
ELSpool
Jul 31, 2003 05:59 AM
1badITR
Jan 22, 2003 09:38 PM
93B17A
Jan 28, 2002 08:42 PM
