Chicken build
Old May 10, 2014 | 01:36 PM
  #126
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: Chicken build
Uh, if you never heat cycled the motor, you don't need to buy all new gaskets.
Old May 10, 2014 | 01:59 PM
  #127
chickenbandit's Avatar
Originally Posted by turbohatch96y7
You brought them all the parts and just assembled it for you?
1200 for labor? Jeezus
This is also why I do all my own work. Shops are shady.
What's the shops name?
Correct I brought them all
the parts but they did machine + assembly.
I'm not going to put them on blast just yet.
I'm going to attempt to get all or most of my money back first.
If they can't then......
Old May 10, 2014 | 06:18 PM
  #128
wantboost's Avatar
Who is Mr Robot?
The heatcycle theory is debatable.
one the head is torqued to yield and the headgasket crushes it's done. If you reinstall the crushed gasket it may not seal properly or could slightly crush even further
although after motor is run a few times the studs do loosen up. the best thing to do is warm the motor up fully, shut it down, and immediately pull the cams and hot torque the studs.
Old May 10, 2014 | 06:20 PM
  #129
wantboost's Avatar
Who is Mr Robot?
Although if this shop couldn't do something as simple as install the pistons properly, most even have IN or intake laser etched onto the top of piston on the intake side.. If not the larger valve reliefs indicate the intake side of the piston, then I would doubt the rest of their work
Old May 10, 2014 | 07:22 PM
  #130
The engine has never been started.
Old May 10, 2014 | 11:51 PM
  #131
rudebwoy's Avatar
Originally Posted by chickenbandit
Very excited. Block is ready.
I may be late on the reply, but those pistons are in backwards. I just scanned the thread did not read all posts.
Old May 11, 2014 | 05:54 AM
  #132
turbohatch96y7's Avatar
Old Jul 1, 2014 | 09:09 AM
  #133
Watch "Chicken bandit first startup" on YouTube
Chicken bandit first startup:
Old Jul 1, 2014 | 09:13 AM
  #134
Got all my lil issues fixed except a small coolant leak. Should be able to get back on it this weekend
Old Jul 1, 2014 | 07:36 PM
  #135
justYncredible's Avatar
It's wU to the sOLdiEr!
nice!
ill be making my video next week when my coil gets in!
Old Jul 2, 2014 | 10:06 PM
  #136
Nice. Ive been watching your build too
Old Jul 6, 2014 | 11:17 PM
  #137
Things going good.
First oil change looked great.
Compression test coming this weekend
Old Jul 6, 2014 | 11:25 PM
  #138
Next step rebuild spindles with new bushing, bearing, joints, tie rods& abs axles
Old Jul 8, 2014 | 09:28 PM
  #139
S!K TEG's Avatar
nice build going on here. by any chance, are you from Arizona?
Old Jul 8, 2014 | 11:35 PM
  #140
Yes
Old Jul 30, 2014 | 12:19 AM
  #141
Has anyone dealt with traction bar to balancer clearance.
They're very close to each other and im wondering whats going to
happen while accelerating and shifting.
Please ignore my leaks.
They were being fixed when I noticed
the clearance.
Old Sep 12, 2014 | 06:37 AM
  #142
Haven't done much of anything to the car lately. Just catching up on bills.
I have noticed that after a longer period at idle, it wants to run pretty warm.
So the next step I want to take before tuning is to coat & wrap everything with heat wrap (mani,uppipe,)
I also want to have a block off behind my intercooler on the turbo side in an attempt to force more air thru the intercooler and radiator. Right now I have a FAL fan (not sure the model) At idle my ECT reached 205 while I was bleeding the system for about 15mi.
Any other recommended tricks would be appreciated.
Old Sep 27, 2014 | 10:15 PM
  #143
S!K TEG's Avatar
amazing build.
Old Sep 27, 2014 | 10:47 PM
  #144
king06's Avatar
Maybe I missed it, but your driving it untuned to break it in? Also, what happened with the pistons being backwards?
Old Oct 7, 2014 | 01:17 AM
  #145
Thanks sik tag.
You're from PHX right?
King06 haven't done much but driven it around the corner. (All motor) still ran horrible.
A lot of idle time.
Need to have it tuned immediately. Due to recent events I'm gonna need a car for work until we get another.
Piston issue was fix awhile back.
Old Oct 7, 2014 | 07:49 AM
  #146
S!K TEG's Avatar
Thanks sik tag.
YUP!
I love this build. I came close to buying the car when you were going to sell the shell.
Old Oct 7, 2014 | 08:34 AM
  #147
I feel like I know u. You know mickey aka dead bird off azht right?
Old Oct 7, 2014 | 09:00 AM
  #148
S!K TEG's Avatar
Probably do and probaly don't, lol. I met him a few times when he had the green hatch, before the white integra.
s0_wavyyy
Engine Machining & Assembly
55
Nov 30, 2018 07:38 AM
Allmotorpride
12
Feb 20, 2017 02:53 PM
civicboy07
Oct 21, 2014 05:44 AM
LuckyToBeBC
Southeast (Sales)
37
Aug 23, 2010 12:44 AM
LuckyToBeBC
Aug 22, 2010 04:14 AM
