Check Engine light - code 67
Old Aug 6, 2001 | 01:47 PM
AzianAvenger's Avatar
New User
Default Check Engine light - code 67
I have gotten used to riding with this freakin light on all the time now. I reset it everynow and then for shiznit and giggles. But really though, anyone knows how to get rid of this check engine error code?
For those of you that do not know...code 67 means you either have on of these problems:
(1) Secondary 02 sensor problem
OR
(2) Catalytic Converter problem
Well people, I have 1998 GSR with no cat. I have replaced the cat with a 2.5" flex pipe. To deal with this bull$hit CEL, I tried to hotwire my ecu by having the secondary O2 read off of the primary O2 but this only worked for like 3 days. The freakin ECU is really smart and compensated. It even freaks out on my S/AFC everynow and then but that is a separate issue.
So after that rewiring job, I have just been dealing with it for a year now.
Is anyone going through this crap because you have no cat?
-AzianAvenger
Old Aug 6, 2001 | 02:09 PM
b18b98's Avatar
Default Re: Check Engine light - code 67 (AzianAvenger)
i heard if you get a 96 ecu and make sure the 02 sensor is in the flex pipe through a bung your won't have a CEL
Old Aug 6, 2001 | 06:46 PM
redline's Avatar
Default Re: Check Engine light - code 67 (b18b98)
The 96 ECU does not always work mine throws this code once in a while
k
streetracerjoey210
Jun 24, 2007 04:48 PM
h22xcivic
Apr 27, 2006 07:51 PM
brad98_teg
Mar 28, 2005 06:17 AM
D3U1LT
Sep 20, 2004 05:24 AM
Crossett
Dec 24, 2001 07:08 PM
